Pocket GPS World :: View topic - A sinple way to convert OV2 files to upi format?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Sygic McGuider/Mobile Maps
kingcarbonel
PostPosted: Thu Jan 29, 2009 2:42 pm    Post subject: A sinple way to convert OV2 files to upi format? Reply with quote
First of all, apologies if this has already been asked!
Whenever I go away on business trips, I always end up staying at Premier Inn hotels. From their website, you can download a POI file in either Tom Tom or Garmin format
I have the Tom Tom one here, is there a method I can use to convert the OV2 file into a format McGuider can understand?
Thanks!
scarymonkey
PostPosted: Thu Jan 29, 2009 5:06 pm    Post subject: Reply with quote
If you get the new convertor from Sygic (here) then you can use OV2UPI 2.3 which converts ov2 files into the UPI format used in McGuider 2008. You can then convert these to the 2009 format using the Sygic convertor easily.
kingcarbonel
PostPosted: Thu Jan 29, 2009 5:35 pm    Post subject: Reply with quote
Thanks Scarymonkey, I'll give it a try!
kingcarbonel
PostPosted: Thu Jan 29, 2009 5:46 pm    Post subject: Reply with quote
And it works a treat - thanks for the quick reply, much appreciated!
kingcarbonel
PostPosted: Fri Jan 30, 2009 10:13 am    Post subject: Reply with quote
Well I had all the cameras installed correctly, but whenever I approach one, McGuider throws up an unexpected error, and crashes out Sad
I think there's a thread about this problem elsewhere already, so I'll do some reading up there first Smile
scarymonkey
PostPosted: Fri Jan 30, 2009 1:20 pm    Post subject: Reply with quote
My guess then is you have a Symbian based phone. Hopefully Sygic will be releasing an updated exectuable for this in the near future.
kingcarbonel
PostPosted: Fri Jan 30, 2009 1:53 pm    Post subject: Reply with quote
ah! Yes, I do, it's a Nokia E65 that it's running on, so that might explain it.
I've deleted the two categories I added, and the software now works quite happily Smile
scarymonkey
PostPosted: Fri Feb 06, 2009 6:27 pm    Post subject: Reply with quote
I forgot to post here after graemesimpson advised me of the new update available using McGuider Assistant (it is an update program on the McGuider SD card) which fixes the crashes you have seen. If you haven't checked or updated it is well worth grabbing the fix.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Sygic McGuider/Mobile Maps All times are GMT + 1 Hour
23.054 (28 May 25)
