tekilachat Occasional Visitor
Posted: Wed Jan 28, 2009 11:58 am Post subject: |
LolitaDamore wrote: | I would only change "Fenetre" by "Fenêtre" ![Cool](modules/Forums/images/smiles/icon_cool.gif) |
it's true, excuse me
bonjour la france ![Very Happy](modules/Forums/images/smiles/icon_biggrin.gif) |
LolitaDamore Occasional Visitor
Posted: Wed Jan 28, 2009 12:15 pm Post subject: |
Euh non, la Belgique ![First](modules/Forums/images/smiles/eclipsee_gold_cup.gif) |
TheGrumbler Occasional Visitor
Posted: Wed Jan 28, 2009 2:30 pm Post subject: |
Hi Linknet,
Here is my German translation for the added phrases in Ultra Skin 6.
TheGrumbler
Blocked Roads="Gesperrte Straßen"
Block Road="Straße sperren"
Remove Block="Sperre entfernen"
Deleting blocked road.="Lösche gesperrte Straße."
Deleting all blocked roads.="Lösche alle gesperrten Straßen."
Find Map Mode="Kartensuche"
Find Map Mode Settings="Einstellungen Kartensuche"
Key Sounds Volume="Lautstärke der Tasten"
Next Turn="Nächstes Abbiegen"
Pop-Up Info Settings="Einstellungen Pop-Up Info"
Pop-Up Info Panel="Zeige Pop-Up Info"
Display Visible POI's Only="Zeige nur sichtbare POIs"
Maximum Search Radius="Maximaler Suchradius"
Lane Information Settings="Einstellungen Spurdaten"
Menu Button Fade Out="Menü Taste ausblenden"
Trip Data Overspeed Warning="Reisedaten Geschw. Warnung"
Show Speed Limit="Zeige Geschw. Limit"
Show Speed="Zeige Geschwindigkeit"
Tilt Up to:="Neigung rauf bis:"
Tilt Down to:="Neigung runter bis:"
Map Full Screen Settings="Einstellungen Karten-Vollbild"
Second Route Event="Folge-Event"
Second Route Event Show At="Zeige Folge-Event ab"
Second Route Event Show if Less Than="Zeige Folge-Event wenn weniger als"
Show House Numbers at:="Zeige Hausnummern ab:" |
vangelis_73 Occasional Visitor
Posted: Wed Jan 28, 2009 4:03 pm Post subject: |
Hi Linknet,
I'm happy to see you back in business
THANK YOU for your new skin !
I see 1 cosmetic problem:
(even with original skin): Settings/Navigation: misalignment for box containing "Restore Lock-to-Position" - must be moved to right.
I know that you don't have time, but you will add in future release FlyOver control?
Thanks |
Giantbiker73 Occasional Visitor
Posted: Wed Jan 28, 2009 7:20 pm Post subject: |
Giantbiker73 wrote: | I'm travelling back home tomorrow so this will be a good test (although I strongly doubt the skin going wrong on me, ofcourse).
Will report if problems occur. |
No real problems during the trip, only 1 question:
- If I am on a motorway (Highway) and have to get onto another motorway, then the map goes to 2D (or tilts in a vertical position, very annoying) at the first warning "leave motorway in 3km" until the final warning "leave motorway", then it goes to 3D again. This happens in 6.0.1 and 6.0.2. It turns out this happens in the default skin as well, so it's not Ultraskin related.
I've reset all user settings and Smartzoom settings are like this:
Zoom in: 170M
Zoom out: 300M
Tilt up: 50 degrees
Tilt down: 70 degrees
Have changed these settings, coarse and fine adjustments, doesn't help.
What to do? I would like a tilted 3D map so I can see the exit on screen. |
linknet Frequent Visitor
Posted: Wed Jan 28, 2009 7:50 pm Post subject: |
Giantbiker73 wrote: | If I am on a motorway (Highway) and have to get onto another motorway, then the map goes to 2D (or tilts in a vertical position, very annoying) |
Turn off "Automatic Overview".
linknet |
Posted: Wed Jan 28, 2009 8:28 pm Post subject: |
TheGrumbler wrote: | Hi Linknet,
TheGrumbler |
Thanks for that, I'll add it to the website as soon as I get some time.
linknet |
Posted: Wed Jan 28, 2009 9:29 pm Post subject: |
Added Version 6.0.3
- Added a working section camera cancel function to the section camera warning icon. The first "Tap" cancels the warning sound as usual and the second "Tap" now actually cancels the section camera so that the next section camera encountered will begin a new monitored section.
- Added coloured backgrounds to the lane arrows on the signpost information panels making it easier to distinguish the correct lane(s) to take (see the screenshots page).
- Modified the Manage Blocked Roads menu so that "Tapping" the blocked road information takes you straight to the location on the map screen. The "Map" button is therefore not required and has been removed.
- Numerous minor cosmetic changes particularly to the Portrait Mode menus.
linknet |
Posted: Wed Jan 28, 2009 9:51 pm Post subject: |
vangelis_73 wrote: | Hi Linknet,
Thanks |
Thanks for the information, I've corrected that and some more. Also check the Manage Road Blocks menu.
No flyover planned I'm afraid.
linknet |
fr0d0 Occasional Visitor
Posted: Wed Jan 28, 2009 10:52 pm Post subject: |
linknet wrote: |
- Added coloured backgrounds to the lane arrows on the signpost information panels making it easier to distinguish the correct lane(s) to take (see the screenshots page). |
sorry to be negative - don't like that can we turn it off?
(imho the original design is clean & clear) |
Auke Occasional Visitor
Posted: Thu Jan 29, 2009 10:42 am Post subject: |
Hi Linknet
I have two requests
i like the way the second Route event looks. Are you planning to make the first route event the same?
are you planning to make a color filter for the night profile. Dimka en Gurjon have something like that on there skins and i like it very much. You can make the colors more dark so it is less bright in the car.
I like your skin a lot. Leave it simple that's the best. |
Posted: Thu Jan 29, 2009 11:21 am Post subject: |
fr0d0 wrote: | linknet wrote: |
Yes, the original design is clean and clear but very difficult to distinguish between the lanes, all they use is dimming of the panel and lane arrows which are not on the route.
The problem is, as shown by my example on the website, that a highlighted panel can also contain dimmed arrows. These are impossible to differentiate in sunlight, and extremely difficult in daylight.
It needed a solution, if you can think of a better one I'll have a look at it.
linknet |
Posted: Thu Jan 29, 2009 11:29 am Post subject: |
Auke wrote: | i like the way the second Route event looks. Are you planning to make the first route event the same? |
Not at the moment, I sometimes consider it but usually find reasons against it.
Auke wrote: | Are you planning to make a color filter for the night profile. Dimka en Gurjon have something like that on there skins and i like it very much. You can make the colors more dark so it is less bright in the car. |
Now that's a good idea, I usually have to minimise iGO, turn down the brightness, and then maximise iGO to achieve that.
linknet |
scope Occasional Visitor
Posted: Thu Jan 29, 2009 5:54 pm Post subject: |
Its great to have Ultra Skin back again.
I have used Gurjons skin for a couple of months now, and it does have more options (more useful, others not so) than Ultra - however I do remember how good Ultra Skin was when I last used it, so will give it a go again.
You have to sort out speed camera warnings and speed camera options though, they are a must.
Thanks for your work. |
Posted: Thu Jan 29, 2009 7:22 pm Post subject: |
linknet wrote: | Giantbiker73 wrote: | If I am on a motorway (Highway) and have to get onto another motorway, then the map goes to 2D (or tilts in a vertical position, very annoying) |
linknet | I'm sure that will help but automatic overview is one of the key features why I use iGO. And since "Intelligent Powersave" doesn't work as it should on my TyTnII, I'm left with no other option.
But I might have solved it in another way. Today I did a reset of all user settings. This solves the problem as well. Turns out that iGO will do this whenever the zoom in/out are on the settings I mentioned before. |
