Mally1957 Lifetime Member
Posted: Wed Jan 28, 2009 9:06 pm Post subject: Changing Paired Phone |
Recently I changed my mobile phone that I have paired with my Tomtom One Version 1.
Now every time I connect my tomtom to computer to update camera database or update via home my tomtom reverts to the original phone along with other settings such as chosen voice, speaker volume and start up screen.
Has anyone a solution to this.
Another issue I have found on changing phone (this is at least true for the Orange network) is that for your phone to connect to traffic you have to disable the orange safeguard lock to enable adult content, why Orange should think connecting to the Tomtom servers warrants an adult content lock I dont know. _________________ Malcolm
A now retired Tomtom 940 v9.541.3145439.1 OS:1493118, GPS v1.20 Boot 5.5120, West Europe Map v1025.9386 |
Andy_P Pocket GPS Moderator
Posted: Wed Jan 28, 2009 10:25 pm Post subject: Re: Changing Paired Phone |
Mally1957 wrote: | why Orange should think connecting to the Tomtom servers warrants an adult content lock I dont know. |
It's because of the bad language you're likely to use, trying to get it to work!
Does your TT really lose its settings when you connect to the PC, or is it ONLY when you connect to Home? |
Calomax Lifetime Member
Joined: Sep 30, 2005 Posts: 988 Location: St Martin's, Guernsey
Posted: Wed Jan 28, 2009 10:27 pm Post subject: |
I don't know if the one is the same as the 720, but I had to delete the old phone before I could pair my new one. _________________ TT Go Essential |
Posted: Wed Jan 28, 2009 10:46 pm Post subject: |
Quote: | Does your TT really lose its settings when you connect to the PC, or is it ONLY when you connect to Home? |
Andy_P yes it is when connecting via the USB cable to the computer and also when running Home, but of course you have to be connected to the computer to run home so I doubt there is a seperate issue there.
Quote: | I don't know if the one is the same as the 720, but I had to delete the old phone before I could pair my new one. |
Calomax the option the one gives you is manage phones it then asks if you want to stay paired with the present phone (ie my new one) then after connecting to computer / Home the setting reverts to my previous phone.
I can see no way in the menu to delete the old phone before pairing with the new phone. _________________ Malcolm
Posted: Wed Jan 28, 2009 10:59 pm Post subject: |
Mally1957 wrote: | Quote: | Does your TT really lose its settings when you connect to the PC, or is it ONLY when you connect to Home? |
Andy_P yes it is when connecting via the USB cable to the computer and also when running Home, but of course you have to be connected to the computer to run home so I doubt there is a seperate issue there. |
That's odd...
Home has a reputation for resetting quite a few things (like POI warning settings), especially when you use Home's on-screen emulator, but I can't see how just connecting the USB cable could have that effect.
Posted: Wed Jan 28, 2009 11:10 pm Post subject: |
Quote: | That's odd...
Home has a reputation for resetting quite a few things (like POI warning settings), especially when you use Home's on-screen emulator, but I can't see how just connecting the USB cable could have that effect. |
Same here at the moment I am stuck with it been a weekly event on a Wednesday when I update camera database.
At least my new phone a Sony Ericsson C902 is a supported phone so I dont have to enter all the settings manually unlike my previous Samsung Z400. _________________ Malcolm
DennisN Tired Old Man
Posted: Wed Jan 28, 2009 11:15 pm Post subject: |
It keeps happening to me Andy. I have decided that it's the way I connect, probably. My 920 has an SDHC card as well as internal, so when I plug in, Home fires up and immediately asks me to select internal or external. I ignore it and carry on doing my thing with Win Explorer. When I've finished, I need to disconnect, so what I do is return to Home and, because it won't allow me to select Device Disconnect until I get rid of the Choose internal or external window, I select one of them, then go for Device Disconnect. It was once even worse than just losing settings. But I think I may have cracked it now (ooops - Murphy's Law!!). I think it may be when I select the internal rather than external. Problem is, I can't reliably duplicate the effect. _________________ Dennis
Two of them are obesiting!! |
Posted: Thu Jan 29, 2009 1:10 am Post subject: |
Quote: | It keeps happening to me Andy. I have decided that it's the way I connect, probably. My 920 has an SDHC card as well as internal, so when I plug in, Home fires up and immediately asks me to select internal or external. I ignore it and carry on doing my thing with Win Explorer. |
This is why I suspect it is not Home causing the problem because I have disabled Home from starting up automatically as a startup program so when I do a windows explorer backup or camera database update only Home does not fire up but I still have the same problem. _________________ Malcolm
Posted: Thu Jan 29, 2009 1:55 am Post subject: |
Mally1957 wrote: | I have disabled Home from starting up automatically as a startup program |
As you should have done, Dennis! |
Posted: Thu Jan 29, 2009 9:31 am Post subject: |
Mally1957 wrote Quote: | Calomax the option the one gives you is manage phones it then asks if you want to stay paired with the present phone (ie my new one) then after connecting to computer / Home the setting reverts to my previous phone.
I can see no way in the menu to delete the old phone before pairing with the new phone | Sorry I can't help then, the One is obviously different from the 720. I couldn't pair my new iPhone until I had deleted the old Nokia 6300. _________________ TT Go Essential |
trevor.dowle Lifetime Member
Posted: Thu Jan 29, 2009 10:37 am Post subject: |
I'm sure I've read somewhere on this forum, that it is possible to have more than 1 phone paired with a TomTom.
I'm glad I read this thread as I was going to try my 3 contract phone instead of my PAYG orange.
Don't want to lose the 'pairing' altogether! _________________ Regards
Trev Dowle
TomTom 730 T |
Posted: Thu Jan 29, 2009 11:34 am Post subject: |
trevor.dowle wrote: | I'm sure I've read somewhere on this forum, that it is possible to have more than 1 phone paired with a TomTom. |
I'm 90% sure you can on the Go models at least.
I haven't got any phones in front of me with bluetooth (4 phones in the family and only mine doesn't have it), but I'm pretty certain one of my Go's is paired with both my wife and my daughter's phones.
Anyone know if I can check that without the phones being here? |
Posted: Thu Jan 29, 2009 11:44 am Post subject: |
I understand you can have multiple pairings - one device, several phones, one phone, several devices.
BUT you can only have one pairing active at any time. _________________ Dennis
Posted: Fri Jan 30, 2009 12:11 pm Post subject: |
Thanks Dennis, If thats the case then its not a problem. _________________ Regards
Trev Dowle
TomTom 730 T |
Posted: Fri Jan 30, 2009 1:05 pm Post subject: |
Yes, I think I was slightly confused. I think my device still had the old phone as being active. I deleted it anyway as I didn't need it paired any more, so I didn't look into deactivating it. _________________ TT Go Essential |
