Posted: Mon Jan 26, 2009 4:00 pm Post subject: |
Well i've messed about with the database and tried it. As i said above, doing the exact same run over and over, if under the limit nothing happens except for the icon appearing. Over the limit icon, alert and bongs.....
Works both on my local junction with simalar setup and the Anstey Road setup.
If i go out later and i remember i might install the original non-CM database and try it too...
I do see what you mean about the help file in POILoader and i did read it several times.... |
Posted: Tue Jan 27, 2009 2:00 pm Post subject: |
Loaded the Consolidated database today - plain vanilla copy, no Ash10 CM or other edits and it seems to confirm my thoughts / findings. Approaching the RedLight cameras i used before i was under the speed limit, slight blip with the right foot and alerts started up, dropping below the speed limit silenced the alerts but the icon remained.
Coming back in other direction i stayed under the limit (of course) all the way through the junction and no alert at all..... |
banjo12 Regular Visitor
Posted: Tue Jan 27, 2009 2:14 pm Post subject: |
PaulB2005 wrote: | Loaded the Consolidated database today - plain vanilla copy, no Ash10 CM or other edits and it seems to confirm my thoughts / findings. Approaching the RedLight cameras i used before i was under the speed limit, slight blip with the right foot and alerts started up, dropping below the speed limit silenced the alerts but the icon remained.
Paul, first of all thank you for your help, I am confused by what you have said do you mean that you have to exceed the speed limit to activate the red light audio camera warning ? |
Posted: Tue Jan 27, 2009 2:22 pm Post subject: |
It would appear so. I also checked this against a Gatso and a Monitron and they exhibit the same behaviour.
I'll check again later today and this week as i may have missed the Initial Proximity Alert.... |
Posted: Tue Jan 27, 2009 2:39 pm Post subject: |
PaulB2005 wrote: | It would appear so. I also checked this against a Gatso and a Monitron and they exhibit the same behaviour.
Would a fix be to change the red light camera to a speed camera as from what you have said this is how it is operating, is it possible that other junctions with this configuration could be acting the same ?
Sorry for harping on but I would like to try and understand the situation. |
Posted: Tue Jan 27, 2009 3:23 pm Post subject: |
Well the only conclusion is i can't get consistant results. Some times it alerts and sometimes it doesn't. Even today i went through 3 cameras under the speed limit and not a murmur until i went over the limit hence my earlier post. However a simulated run of the route confirms the camera do generate an alert under the speed limit....
I'll come back to this another time..... |
Posted: Fri Jan 30, 2009 3:29 pm Post subject: |
banjo12 - i may have missed it in the thread but what model sat nav are you using? |
Posted: Fri Jan 30, 2009 3:58 pm Post subject: |
PaulB2005 wrote: | banjo12 - i may have missed it in the thread but what model sat nav are you using? |
Paul, it is a Garmin Nuvi 310D |
Posted: Fri Jan 30, 2009 4:00 pm Post subject: |
Also what map version are you using? |
Posted: Fri Jan 30, 2009 4:06 pm Post subject: |
PaulB2005 wrote: | Also what map version are you using? |
City Navigator Europe NT v9 |
Posted: Sat Jan 31, 2009 2:30 pm Post subject: |
I don't know if this has any bearing on the problem but the voice warnings are VERY LOUD, making the Nuvi unit vibrate and being slightly distorted  |
