mpwilson99 Lifetime Member
![](modules/Forums/images/avatars/15509806134a81c3cd19d71.jpg)
Joined: Jun 30, 2007 Posts: 462 Location: Hickstead, Sussex
Posted: Tue Jan 13, 2009 9:09 am Post subject: POI Mulitifiles Collator |
Hi all,
Is there a little proggy out there which will collate all your POI .ov2 into one single file at a click of a button??
I can do this by opening one by one and adding them to a main file, but its a right pain !
Any ideas?
MPW _________________ TomTom 700 GO user since Dec 2005.
TomTom PDA XDA user since Dec 2007.
TomTom HTC HD2 user since Jul 2012. |
Daggers Lifetime Member
![](modules/Forums/images/avatars/gallery/pyramid.jpg)
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Tue Jan 13, 2009 10:18 am Post subject: |
POIEdit will allow you to do append POI files together (just Google POIEdit!).
Also if you select "Combine subcategories into category file " when you download, you can merge up to 20 downloaded sub-categories into a single file.
On the other hand, you do realise that when you merge files together like this, you only get one icon which applies to all POIs? This might be what you want to do, but I thought I had better point it out, just in case! |
Posted: Tue Jan 13, 2009 10:42 am Post subject: |
Thanks Daggers, I realise it will only be one poi icon, thats all i need for this particular requirement.
Its more for personal pois rather then ones from this site.
Will give POIEdit a try (again?)
Posted: Tue Jan 13, 2009 2:22 pm Post subject: |
Thanks again Daggers,
POIedit did seem to work!
I did have to edit some of the .ov2 files, and give them an `ending remark` like
; 1 record written, 0 deleted bytes ignored, 344043 bytes not processed or i would get an error message!
Andy_P Pocket GPS Moderator
Posted: Tue Jan 13, 2009 2:58 pm Post subject: |
mpwilson99 wrote: |
; 1 record written, 0 deleted bytes ignored, 344043 bytes not processed or i would get an error message! |
Hmm... never seen that, and I use POI edit at least once or twice a week.
Where were these POI files from? I'm usually only dealing with the ones from this site. |
GerryC Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/web.jpg)
Posted: Tue Jan 13, 2009 4:29 pm Post subject: |
I've seen a similar "comment" footer to the text file created by dumpov2 which is ignored when making the ov2 file with makeov2. These are both DOS programs to decrypt and encrypt ov2 files. As ov2 files are encrypted, there would not be any plain text comments like this in them.
I don't have it on this PC, but POIEdit is a Windows program. IIRC you use File-Amend or something similar to merge the POI data from separate ov2 files before saving the result. _________________ Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount |
Posted: Tue Jan 13, 2009 7:24 pm Post subject: |
GerryC wrote: | IIRC you use File-Amend or something similar to merge the POI data from separate ov2 files before saving the result. |
"File - Append"
(Then "Save as...") |
