Godfather40 Occasional Visitor
Posted: Tue Jan 13, 2009 12:35 am Post subject: PGPSW Speed Cameras and POI's |
When you down load the PGPSW speed camera and POI's onto your sat nav unitdo you need to remove the relevant TOMTOM files from it first to prevent any conflicts between the two versions of data? |
Steveee Lifetime Member
Joined: Dec 16, 2003 Posts: 203 Location: Colchester, Essex
Posted: Tue Jan 13, 2009 12:46 am Post subject: |
No, you can run both. The only issue is that you may not get the warnings you expect if the TT speed camera and PSPSW are set to trigger at the same point. _________________ Steveee
Where am I?
GO 920 (retired)
Garmin Oregon 550T
Garmin Drivesmart |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Tue Jan 13, 2009 12:49 am Post subject: |
You can save a copy via TT HOME, then remove them from the unit totally again via TT HOME. Or just disable them on the menus. |
253 Lifetime Member
Joined: Mar 05, 2007 Posts: 1058 Location: The green bit between the M40, M4 and M25.
Posted: Tue Jan 13, 2009 8:34 am Post subject: |
You don't need to remove the TT files, but I would advise that you at least 'turn them off', deselect them, so that you don't get double warnings.
eg POI, say petrol stations. The TT poi are mostly 'well out' because they have been entered according to a post code. The result is that they can show up in the middle of housing estates, or roads 3-4-5 removed from where they actually are.
Camera warnings the same. The TT cameras are not updated as regular as the ones on this site, result is that you get warnings for cameras no longer there, and more importantly - you don't get a warning for camera that is there.
I would advise doing a complete back up of your device using windows explorer, or similar if on a mac. Then you can always go back to a 'factory copy' if need be.
I have all the TT cameras/POI deselected, and only run the PGPSW stuff. _________________ Triumph Tbird 1700. And now a Bonnie T100. |
Daggers Lifetime Member
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Tue Jan 13, 2009 10:23 am Post subject: |
253 wrote: |
That's not down to using postcodes - it's just bad data in the first place. 99% of individual postcodes will related to a number of properties in the SAME street, not in different roads. |
253 Lifetime Member
Posted: Tue Jan 13, 2009 7:27 pm Post subject: |
Daggers wrote: | 253 wrote: |
Thats a good point, I hadn't considered the bad data bit. Just assumed someone had obtained a load of post code data and loaded into a poi. _________________ Triumph Tbird 1700. And now a Bonnie T100. |
Andy_P Pocket GPS Moderator
Posted: Tue Jan 13, 2009 9:16 pm Post subject: |
I think on the whole, for anything upto say 3-400 yards it IS down to postcodes...
It's unlikely businesses would have "bad data" for the POI files they create for their own branches, but those are often way out. |
Posted: Wed Jan 14, 2009 12:48 am Post subject: |
Only if they've got the wrong lat/long for the postcode. 300-400 yards seems a long way for a postcode to be incorrect, but it is possible - though generally only if it's in the same street.
Do we have any examples that we can actually do some research on? |
dlpruk Regular Visitor
Joined: Dec 24, 2006 Posts: 88 Location: Nottinghamshire
Posted: Wed Jan 14, 2009 2:02 am Post subject: |
Daggers wrote: |
Compare the PGPS location of the BP filling station at 53.15816/1.14699 - which I know is right because I put it there - with where TT thinks it is - up a lane!
David |
Posted: Wed Jan 14, 2009 11:00 am Post subject: |
BP record the postcode of this service station as NG19 0HL.
For this postcode, the Post Office records 26 different addresses, all in Clipstone Road West - between nos. 80 & 122 (even nos. only). This includes a nursing home and a Spar shop, but no petrol station. I can't find any Post Office record of a petrol station in Clipstone Road West.
Which lane does TT think it is located in? I could check the Post Office database for that lane to see if it's there, but we really need details of the address that TT are using to locate it. |
Posted: Wed Jan 14, 2009 1:26 pm Post subject: |
Daggers wrote: | BP record the postcode of this service station as NG19 0HL.
There is a Spar at that BP station.
I can't be precise about where my TT thought it was as I've deleted all TT's POIs and replaced 'em with ones that work. (Can you guess the source?)
But I seem to remember it was in a lane towards Poplar Grove - but that no longer exists anyway as the whole area is now a new housing development.
David |
253 Lifetime Member
Posted: Wed Jan 14, 2009 4:32 pm Post subject: |
When I did my post it was the BP poi that I was thinking of to be honest.
I remember that when I 1st started using my TT710, they were well off. In fact a couple I actually passed didn't even show up on the TT, which is why I said what I said.
off the top of my head, I think one of them was in Victoria Road Ruislip, 37525 is the PGPSW site. The TT icon was appearing in the middle of the flats to the bottom and right.
I must admit I did 'guessedamate' the distance involved. _________________ Triumph Tbird 1700. And now a Bonnie T100. |
Posted: Wed Jan 14, 2009 6:02 pm Post subject: |
Google Search on my 540 can't find my BP Clipstone Road site under that name, nor Spar; and it thinks the BP at the junction of Chesterfield Road North and Abbott Road in Mansfield Woodhouse is yards up Chesterfield Road North when actually it's on the corner and has entrances from both roads.
Fuel Prices gets the Clipstone Road BP in the right place but thinks it has Ultimate Diesel, which it doesn't!
Wondrous innit?
David |
Posted: Wed Jan 14, 2009 10:50 pm Post subject: |
To be fair, if we're trying to prove that it's bad data causing these TT POI problems, I need to know some fairly precise details of one of these POIs is located - where TT thinks it is, and I also need it to be in a completely different road to where it is actually located.
None of the examples so far have really given enough information. |
theripper Pocket GPS Verifier
Joined: Feb 07, 2006 Posts: 581 Location: Medway Towns, Kent
Posted: Thu Jan 15, 2009 1:20 am Post subject: |
You want to try looking for the Cobham Services on the A2 in kent the road system shows on the map ok but the petrol stations show as being at the end of scotland lane which is the other side of the channel tunnel rail link(Postcode DA12 3BH) this pc covers both service stns. If you look on google maps you can see just how far out they are.(Postcode taken from Esso site list)
theripper |
