Pocket GPS World :: View topic - Controlling TT HOME
Controlling TT HOME
Goto page Previous  1, 2
Oldboy
PostPosted: Mon Jan 12, 2009 4:49 pm    Post subject: Re: Controlling TT HOME Reply with quote
alanji wrote:
Oldboy wrote:
Do you have a HOME Icon in the Sys Tray?
If so, Right Click and select Exit.
If that works you will have to do the same every time that HOME is used. Sad
That's done it - but I never used to have to do that!!
I was only aware of it since 2.5.x.xx, and it annoyed me. Evil or Very Mad
MrT
PostPosted: Mon Jan 12, 2009 4:55 pm    Post subject: Reply with quote
You need to delete the registry entry:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\TomTomHOME.exe "C:\Program Files\TomTom HOME 2 \HOMERunner.exe"-s
This may vary depending on the directory you installed it to.
Drivelux
PostPosted: Mon Jan 12, 2009 5:03 pm    Post subject: Reply with quote
Thanks for getting to the bottom of it!
Whatever I used to stop it must have completely deleted the reference there, because it isn't mentioned at all now.
alanji
PostPosted: Thu Jan 15, 2009 9:14 pm    Post subject: Reply with quote
Sorry, can someone remind me how to edit the registry? I'll try to remember Rolling Eyes
Alan
Go 750 LIVE Europe Map 870.3406
Go 720 W Europe Map 865.3245
One XL W Europe. Map 715.1689
Dell Axim & TT3
Psion 5mx & Routeplanner
pcaouolte
PostPosted: Thu Jan 15, 2009 10:14 pm    Post subject: Reply with quote
Start Button|Run...|type regedit into the box|press enter
If in doubt don't mess with it as it can cause major problems if you make mistakes.
Paul
MrT
PostPosted: Fri Jan 16, 2009 9:49 am    Post subject: Reply with quote
if you edit the registry I suggest you export the "run" key before you delete anything. That way if you delete too much or cause an issue you can import it again.
To do this in regedit click on the folder in the left pane you want to export which would be "run" in this case. Click in the menu bar on FILE then EXPORT then choose a file name and directory to save it to then save it. If you later want to import it again you can either double click on the file you saved in windows explorer or use IMPORT in regedit.
Of course if Home had been well written you would have had the option "start automatically with windows".
Drivelux
alanji
PostPosted: Fri Jan 16, 2009 5:09 pm    Post subject: Reply with quote
Thanks for the advice (both). No TomTom file in the registry so I guess I am stuck with deleting from the system tray every time I run it.
Alan
Dell Axim & TT3
PaulB2005
PostPosted: Fri Jan 16, 2009 5:31 pm    Post subject: Reply with quote
You can CAREFULLY use AutoRuns to remove it.
Download, Extract, Run Autoruns.exe, Agree to License, Wait for program to fill up, Click "Logon" Tab, highlight TomTom entry and hit Delete. Say Yes.
Job Done. Close AutoRuns.
Use at your own risk etc etc etc
alanji
PostPosted: Fri Jan 16, 2009 5:44 pm    Post subject: Reply with quote
Thanks Paul. I'll give it a try.
Alan
Dell Axim & TT3
chelsky
PostPosted: Fri Jan 16, 2009 6:53 pm    Post subject: Reply with quote
I used msconfig and on the startup tab I removed the tick for tt home. Fine. Next time I connected my tt it asked me if I want to install Home!!!
chelsky
Page 2 of 2
