alanji Lifetime Member
![](modules/Forums/images/avatars/gallery/harrypotter4.jpg)
Posted: Mon Jan 12, 2009 11:36 am Post subject: Controlling TT HOME |
Despite unchecking the "Start Home every time I connect to this computer" box in preferences, Home still insists on starting every time I connect.
Can anyone suggest how to stop this? I do not want to disable Home completely. _________________ Alan
Go 750 LIVE Europe Map 870.3406
Go 720 W Europe Map 865.3245
One XL W Europe. Map 715.1689
Dell Axim & TT3
Psion 5mx & Routeplanner |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Mon Jan 12, 2009 12:38 pm Post subject: |
Start--Run--Msconfig.
Startup tab.
Is Home checked? If so, uncheck. Click Apply. Restart Computer. When the box appears advising that stuff has been checked, check the box saying not to show it again. click 'ok'. _________________ David |
Posted: Mon Jan 12, 2009 1:26 pm Post subject: |
dhn wrote: | Start--Run--Msconfig.
Startup tab.
Is Home checked? If so, uncheck. Click Apply. Restart Computer. When the box appears advising that stuff has been checked, check the box saying not to show it again. click 'ok'. |
Thanks, dhn. Unfortunately, there is no "Home" programme in the start up folder. _________________ Alan
Dell Axim & TT3
Posted: Mon Jan 12, 2009 1:49 pm Post subject: |
Use Explorer to look at the contents of the unit. (I'm going from memory now, and THAT is a scary thing!).
I believe there is a text file called autorun.inf.
If so, I believe you can put a # sign at the beginning of the line referring to the starting of Home. It's about the 4th line down. _________________ David |
Posted: Mon Jan 12, 2009 1:59 pm Post subject: |
dhn wrote: | Use Explorer to look at the contents of the unit. (I'm going from memory now, and THAT is a scary thing!).
If so, I believe you can put a # sign at the beginning of the line referring to the starting of Home. It's about the 4th line down. |
Thanks David, but it seems TT Home is not to be controlled.
I have tried two hashes but Home still opens
File now reads:
[autorun]
#action=Run TomTom HOME
#open=InstallTomTomHOME.exe
label=TomTom
icon=tomtom.ico
[DeviceInstall]
#This section is empty; autorun will not install device drivers to your PC. _________________ Alan
Dell Axim & TT3
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Mon Jan 12, 2009 2:08 pm Post subject: |
Do you have a HOME Icon in the Sys Tray?
If so, Right Click and select Exit.
If that works you will have to do the same every time that HOME is used. ![Sad](modules/Forums/images/smiles/icon_sad.gif) _________________ Richard
TT Via 135 App 12.075: Europe Map v1140 |
Posted: Mon Jan 12, 2009 2:11 pm Post subject: |
Darn!! I forgot to ask that, Oldboy. _________________ David |
Andy_P Pocket GPS Moderator
Posted: Mon Jan 12, 2009 2:14 pm Post subject: |
Oldboy wrote: | Do you have a HOME Icon in the Sys Tray?
If that works you will have to do the same every time that HOME is used. ![Sad](modules/Forums/images/smiles/icon_sad.gif) |
I've managed to stop it running on this PC, but I have to admit I've forgotten how I did it!
First you can try looking on the other tabs in msconfig (possibly in Autoexec.bat) - that's how I've done it in the past or on other PCs. But this time I've got nothing obvious that I've unticked in msconfig.
I also have a couple of utilities called "Startup monitor" and "Startup Control Panel" installed on this PC (downloadable from HERE) which install a new control panel entry and will probably do the trick for you (although once again, this doesn't seem to be how *I* stopped it this time!)
On my work PC, I had something similar called "StartupCop" (from
HERE for the free version) which runs as an accessory program. That should be able to kill it too. ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
Daggers Lifetime Member
![](modules/Forums/images/avatars/gallery/pyramid.jpg)
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Mon Jan 12, 2009 2:22 pm Post subject: |
alanji wrote: |
Thanks, dhn. Unfortunately, there is no "Home" programme in the start up folder. |
Are you looking at the StarttUp tab in MSConfig, or the contents of the StartUp folder from your Start menu? The two are very different, and MSConfig contains many more programs that run on StartUp. |
Posted: Mon Jan 12, 2009 2:43 pm Post subject: |
Trouble is, as I say above, Home seems to keep changing the way it autoruns, and this time there's nothing in the Startup tab for HomeRunner or similar.
But it can be done! |
Bukton Lifetime Member
Posted: Mon Jan 12, 2009 2:45 pm Post subject: |
I had the same problem until I downloaded CCleaner from File hippo. Under tools, you can disable all the programs you don't want to start up. However, if you 'update' the program, you'd need to re-disable [sic] it. ![Laughing](modules/Forums/images/smiles/icon_lol.gif) |
Posted: Mon Jan 12, 2009 3:09 pm Post subject: |
Curiouser and curiouser...
I've got CCleaner installer on this machine AS WELL (maybe all these "double utilities" are something to do with why my PC takes so long to boot up! ) - and there's nothing about Home or Homerunner mentioned there either!
Wish I could remember what I did to kill it! |
Posted: Mon Jan 12, 2009 3:24 pm Post subject: |
Did you go into the Registry? _________________ David |
Posted: Mon Jan 12, 2009 3:29 pm Post subject: Re: Controlling TT HOME |
alanji wrote: | Despite unchecking the "Start Home every time I connect to this computer" box in preferences |
Ahhh... Are we all talking about the same Home version?
I have v2.5.2.60 (seen on the Help/About TT Home menu) and I don't HAVE that option in the preferences menu any more.
The relevant tickbox on the General tab is now changed to "Start Home automatically when I connect my device to my computer"
dhn wrote: | Did you go into the Registry? |
Maybe... I had a quick trawl through it this morning to see if I'd edited something I could still see, but no luck.
I was searching for "Home", but there's a lot of spurious stuff like "home networking" when you leave the search as vague as that, so I migh have missed something! |
Posted: Mon Jan 12, 2009 3:53 pm Post subject: Re: Controlling TT HOME |
Andy_P wrote: | alanji wrote: | Despite unchecking the "Start Home every time I connect to this computer" box in preferences |
Yes, 2.5.2.60. I was lazy and typed the tab wording from memory.
Daggers wrote: | Are you looking at the StarttUp tab in MSConfig, or the contents of the StartUp folder from your Start menu? The two are very different, and MSConfig contains many more programs that run on StartUp. |
Yes, msconfig. Though I did find some there which I was not aware were running and have deleted them.
If that works you will have to do the same every time that HOME is used. Sad |
That's done it - but I never used to have to do that!!
Thanks, folks - and I must have a look at the sugggested start up cleaners - look useful. _________________ Alan
Dell Axim & TT3
