Pocket GPS World :: View topic - Tom Tom Rider V2 Version 7.901
murdoch
PostPosted: Sat Jan 10, 2009 9:17 am    Post subject: Tom Tom Rider V2 Version 7.901 Reply with quote
I have installed the speed camera maps and the additional voice files (ogg) speedzoned which i have copied to the maps directory and also the sound folder. However when enabling the sound option i hear nothing, I am then unable to alter the sound in any way. Are the voice files compatable with with my V2 Rider? Regards
PostPosted: Sat Jan 10, 2009 10:55 am    Post subject: Reply with quote
Welcome to the forum, after you added the ogg files to the map folder you neeed to configure each speed camera warning by going through Change Preferences/ Manage POI/ Warn When Near POI select the first PGPSW speed camera category. Does the device offer any sound selection page where you can choose bells/ beeps etc? - if not it is probably working.
Try a run out past a camera, or simply use AtoB/ Advanced Planning and plan a route past a camera, then use Route Demo to play back the route, you will obviously need the helmet on to be able to hear the warning sounds though - Mike
PostPosted: Sat Jan 10, 2009 9:57 pm    Post subject: Reply with quote
There is no point in adding the sound files to BOTH places.
You should EITHER add them to the same map folder as the .ov2 data files and they should be assigned automatically WHEN you do the "warn when near" setup.
OR you can add them to the "sounds" folder, in which case they should show up on the sound effects chooser page.
22.063 (19 Jun 24)
