Pocket GPS World :: View topic - POI's onto pna250
POI's onto pna250
chippy24
PostPosted: Fri Jan 09, 2009 4:12 pm    Post subject: POI's onto pna250 Reply with quote
Hi How do I put the pocket gps POI's onto the map SD card and how do I unzip them to use on tomtom navigater 5 mobile
philpugh
PostPosted: Fri Jan 09, 2009 5:06 pm    Post subject: Reply with quote
There's a detailed guide to be found here
All you need to do is unzip the file and put the files into the particular map directory you are using. The name of this directory varies depending on which map you are using and which version sometimes.
If you have multiple map directories they need to be placed into each one.
Phil
chippy24
PostPosted: Thu Jan 15, 2009 11:41 pm    Post subject: Unzipping POI's Reply with quote
What program do you use to unzip the poi's? I'm new to doing this, so I am not sure how to unzip
PostPosted: Fri Jan 16, 2009 12:33 am    Post subject: Reply with quote
If you are using Windows XP or Vista on your PC, you don't need any extra programs.
Just right-click on the zip archive and select "extract all" from the drop-down menu.
If you are using a Mac, then I think "Stuffit Expander" is liked....
chippy24
PostPosted: Fri Jan 16, 2009 10:14 am    Post subject: extracting files Reply with quote
Cheers for the info on how to extract the poi files, I can now give it a go . thanks
