Pocket GPS World :: View topic - BIG PROBLEMS!!!
BIG PROBLEMS!!!
Goto page Previous  1, 2
PostPosted: Wed Jan 07, 2009 6:50 pm    Post subject: Reply with quote
As long as you have a backup then there is no problem in formatting the device - Mike
philpugh
PostPosted: Wed Jan 07, 2009 7:00 pm    Post subject: Reply with quote
As it's flash memory there's no real point in formatting it. You normally format (then restore) discs to improve access times. This doesn't apply with solid state memory. Access times are uniform. Just delete what you don't need. This way it helps to prevent you accidentally removing something that is crucial.
There's a school of thought that says you shouldn't go around doing too many unnecessary writes to a flash device - it will eventually wear it out. Crucial (the memory suppliers) state 1million read/write cycles - so if you want to format it go-ahead - live dangerously Laughing
The answer given by Crucial is here. I do like the last paragrapph about Limited Lifetime Warranty
Phil
raptornexuss
PostPosted: Wed Jan 07, 2009 8:02 pm    Post subject: Reply with quote
ok thanks guys for your help Smile
Page 2 of 2
22.063 (19 Jun 24)
