Pocket GPS World :: View topic - computer voice on TT720
Tedricks1
PostPosted: Wed Jan 07, 2009 4:13 pm    Post subject: computer voice on TT720 Reply with quote
I downloaded computer Kate on to my sd card but she wont talk on my TT720.
All ok on the computer when i try it, I have just updated to the latest map
and it still wont work, can anybody help
PostPosted: Wed Jan 07, 2009 4:16 pm    Post subject: Reply with quote
Welcome to the forum, I assume you downloaded and installed this using TomTom Home? - try resetting the device by giving the reset switch on the base of the device a prod with a paperclip, you won't loose any settings - Mike
Tedricks1
PostPosted: Wed Jan 07, 2009 4:34 pm    Post subject: Reply with quote
Hi Mike Still wont work, press the test button and nothing. All the other voices are ok, and yes every thing was don on TT Home.
PostPosted: Wed Jan 07, 2009 4:47 pm    Post subject: Reply with quote
What software version is your device running, tap the Sat strength meter (Lower right corner) followed by the version box and it will state the software version on the resultant page - Mike
Tedricks1
PostPosted: Wed Jan 07, 2009 4:55 pm    Post subject: Reply with quote
8.300 AND MAP V815.2003 Ted
PostPosted: Wed Jan 07, 2009 5:23 pm    Post subject: Reply with quote
Why can't you put the Kate voice in the LoquendoTTS folder on the device - Mike
Tedricks1
PostPosted: Wed Jan 07, 2009 5:50 pm    Post subject: Reply with quote
Mike I have only got 4.5mb left on the device, and the sd card is almost empty- Ted
PostPosted: Wed Jan 07, 2009 6:01 pm    Post subject: Reply with quote
You might be better putting the "Western_Europe" map folder on to the SD card which will free up a considerable amount of room on the device, then put the Kate files where they usually reside on the device in the LoquendoTTS folder.
I have never tried splitting the LoquendoTTS folders and files between the two storage locations on the device - Just because Home let you do it doesn't mean to say it will work! - Mike
Tedricks1
PostPosted: Wed Jan 07, 2009 6:05 pm    Post subject: Reply with quote
I know this might sound silly, but how do I get the map on to the sd card.
sorry Ted
PostPosted: Wed Jan 07, 2009 6:25 pm    Post subject: Reply with quote
Start by making a full back up of the device using Windows Explorer, there is a guide on the FAQ page see #1 on This Page.
Once you have the full backup you need to put the SD card into a card reader (or put it in the TomTom device which can act as a card reader).
Locate the backup on the PC and find the folder named "Western_Europe" right click this and select "Copy" from the pop up, locate the drive letter associated with the memory card and right click on it, from the pop up select "Paste"
Delete the Western_Europe" map folder on the device and you will have lots of space available on the device memory - Mike
PostPosted: Wed Jan 07, 2009 6:30 pm    Post subject: Reply with quote
Easiest way is to use Windows Explorer, rather then Home.
With the TomTom connected to the PC, start Windows Explorer or My Computer (NOT Internet Explorer) and the TT will be shown as two new disk drives. The first (lowest letter in the alphabet) is usually the SD card slot and the other is the internal memory.
Simply go to the entire "Western Europe" folder on the internal memory, right click on it and select "copy", then select the SD card, right click in the Explorer window and select "paste". Finally, delete the original folder on the internal memory.
This is similar to how you create backups in the preferred way... in that case you select EVERYTHING, and copy/paste it to a new folder somewhere safe on your PC.
EDIT - Gah! beaten again! Crying or Very sad Similar process, but Mike's order is better, because you end up doing that vital backup FIRST....
Tedricks1
PostPosted: Wed Jan 07, 2009 7:34 pm    Post subject: Reply with quote
Thank you both for your helpI will give it ago later and hope it sorts out the voice problem. This is the first time I have used the forum and im very impressed with the very prompt reply thanks again -Ted
Tedricks1
PostPosted: Wed Jan 07, 2009 8:04 pm    Post subject: Reply with quote
Hi me again yes it works im HHHHapy thanks again guys. all the best Ted
PostPosted: Wed Jan 07, 2009 8:10 pm    Post subject: Reply with quote
Maybe I can get in first to say "well done" then! Very Happy
