Pocket GPS World :: View topic - OS Map references
OS Map references
baldock
PostPosted: Tue Jan 06, 2009 1:43 pm    Post subject: OS Map references Reply with quote
Is there any way I can use OS map references in a TomTom 530 ?? ie SU 870 899 ( this is a random set of figures)
Work have now started giving me these refs as to job placements !!
DOH ! or is it time for another toy ????
Cheers to the Gurus
Baldy
pcaouolte
PostPosted: Tue Jan 06, 2009 2:00 pm    Post subject: Reply with quote
There is no way that I am aware of to enter OS map references into a tomtom.
Various web based or PC based converters are available, see example here, that can convert OS map references to Lattitude & Longitude. This can then be entered into your tomtom.
Entering your example of SU870899 into the above converter and selecting Landranger Grid gives Lattitude: N51:36:04 ( 51.601232 )
Longitude W0:44:43 ( -0.745253 ) .
Paul
philpugh
PostPosted: Tue Jan 06, 2009 4:12 pm    Post subject: Reply with quote
Check that whatever software you use also converts the datum. Otherwise you can be between 50 and 150 metres out depending on your location in UK.
edited to add:
Sorry - meant to say my nuvi 660 allows OSGB references to be entered - not that it helps you Razz
Phil
baldock
PostPosted: Wed Jan 07, 2009 2:22 pm    Post subject: Reply with quote
Thanks guys... I think I will have to start looking for another satnav really Sad
Need ease of access to the OS refs. either that or get a pda with memory map as a second unit ?
stuart
PostPosted: Wed Jan 07, 2009 6:28 pm    Post subject: Reply with quote
There is a programme called ITN Converter......See Here http://translate.google.com/translate?hl=en&ie=UTF-8&oe=UTF-8&langpair=fr|en&u=http://benichougps.blogspot.com/
You can enter in your OS Lat and Long and export it into a TomTomFile then add that into a New Favourites folder...
