Pocket GPS World :: View topic - 720 & Dash Mount
720 & Dash Mount
sturgi
PostPosted: Sat Jan 03, 2009 6:30 pm    Post subject: 720 & Dash Mount Reply with quote
I have ordered a 720, I currently have a 710 that I fix to a disk stuck on my dash. Looking at the 720 mount can anyone tell me if it can be attached to a dash disk mount.
Sturgi
PostPosted: Sat Jan 03, 2009 7:10 pm    Post subject: Reply with quote
Yes the x20/ x30 mount will work with a dash disk - Mike
MrT
PostPosted: Sun Jan 04, 2009 12:59 pm    Post subject: Reply with quote
I assume the x20 suction mount is the same as the x30? I cannot use the supplied x30 mount on the dash on my car as the arm on the mount is shorter than the mount height on the unit.
So if my x30 had the bottom of it flat on the dash the suction mount is about 8mm above the dash as in the picture below. The only way is to either have the unit overhang the front of the dash or tilt it upwards at around 45degrees and then the plug will not fit in the bottom.
Drivelux
RATOM
PostPosted: Sun Jan 04, 2009 1:37 pm    Post subject: 720 Dash Mount Reply with quote
I have also been looking for a dash mount as well but without luck. Saw one, however, in Halfords, which is quite heavy and is said to stick to the dashborad even if there is lot of movement. Link here.
But I wasn't quite sure so asked the guy there if I could try it but he did not seem willing. I did not buy.
I prfer the above one though to others as, for them, one has to use adhesive plates on the dash.
Has anyone tried the above?
best
RATOM
MrT
PostPosted: Sun Jan 04, 2009 2:09 pm    Post subject: Reply with quote
I bought one very similar from blueunplugged made by Arkon and make sure you get the one with the mounting bracket for the x30 or you will still have the issue shown in my photo above.
The standard TT supplied x40 mounting bracket works fine on these "cushions"
http://www.blueunplugged.com/p.aspx?p=135644
Drivelux
PostPosted: Sun Jan 04, 2009 2:40 pm    Post subject: Reply with quote
Arkon's mounts were reviewed back in June 2008 here.
nbg
PostPosted: Sun Jan 04, 2009 4:08 pm    Post subject: Reply with quote
I got the Arkon base and mount from ebay for an upcoming trip including a lot of driving in California. I've tested it out on some tight cornering roads in the UK and it hasn't moved at all.
I'm very impressed, as is my wife, as she doesn't have to put anything on her windscreen that will mark and it fits in the central cubby hole of an SLK when not in use.
Calomax
PostPosted: Sun Jan 04, 2009 4:09 pm    Post subject: Reply with quote
I have one of these http://www.blueunplugged.com/p.aspx?p=135647 for my 720 and it's excellent
TT Go Essential
sturgi
PostPosted: Sun Jan 04, 2009 8:38 pm    Post subject: Reply with quote
Thanks for the updates, looks like what I currently have won't work unless I get a different mount. Looks like attached to the windscreen for a little while.
Sturgi
23.054 (28 May 25)
