dio Occasional Visitor
Posted: Tue Dec 30, 2008 10:33 pm Post subject: Nuvi 205T or 300T |
I've just bought a 300T for £89 in Tesco, unusually for me I didn't take a look round to see if this was a good deal as I thought for a traffic enabled device this was pretty good.
However, I've seen the 205T in Halfords tonight for £10 more than I paid for the 300T, the question is, is it worth me packing the 300T up and taking it back? Is there much of a difference that would make the 205 a better buy? |
Posted: Tue Dec 30, 2008 10:46 pm Post subject: |
The 205T is newer but for a full comparision click here |
StuartStrangeboy Regular Visitor
Posted: Thu Jan 01, 2009 11:40 am Post subject: |
I would take the 300 back as it is a discontinued product, the 205 has all the latest software so you can add third party content and do much more with it.
The price you paid for the 300 is also too high anyway. |
McGoo Occasional Visitor
Posted: Fri Jan 02, 2009 4:06 am Post subject: |
Hi Dio
I also bought a 300T from Tesco Direct.
I've downloaded the POI loader and web updater software from www.garmin.co.uk and the speed cameras loaded no problem at all. There is also an update to version 6 of the software and the GTM software available.
I'm going to try it out for the first time tomorrow so I'll let you know how it goes.
From PaulB2005's comparison link it doesn't look like the 205T gives you anything that the 300T doesn't. It's slightly smaller but slightly heavier. The 300T has a few apps that the 205T doesn't, but I'm not sure I would use any of them anyway. The big plus for me is battery life of the 300T is 8 hours compared to 4 hours for the 205T. The 205T has 1000 waypoints, but do you need them? Also, the memory cards are SD v Micro SD. I have loads of SD cards so I know which I prefer :o) It says the 205T doesn't have 3D view, this would be a big negative for me.
I've had a good look on t'internet and I don't see a better deal for the 300T so I think we got a very good deal. Also, no mention of it being discontinued on the Garmin site.
StuartStrangeBoy, where did you get your info about it being discontinued and where can you get it cheaper than £89?
Posted: Fri Jan 02, 2009 1:39 pm Post subject: |
McGoo wrote: | Hi Dio
From PaulB2005's comparison link it doesn't look like the 205T gives you anything that the 300T doesn't. It's slightly smaller but slightly heavier. The 300T has a few apps that the 205T doesn't, but I'm not sure I would use any of them anyway. The big plus for me is battery life of the 300T is 8 hours compared to 4 hours for the 205T. The 205T has 1000 waypoints, but do you need them? Also, the memory cards are SD v Micro SD. I have loads of SD cards so I know which I prefer :o) It says the 300T doesn't have 3D view, this would be a big negative for me.
StuartStrangeBoy, where did you get your info about it being discontinued and where can you get it cheaper than £89? |
I think I'd arrived at the same conclusion. Firstly, there is a 3D view. The thing that finally swung it for me was the 205T comes with a GTM25 for Traffic alerts, while this does have an input for an external antenna it also uses its own charger, although this is good in the repect that it would retain the traffic messages but it means two chargers and all the related wires.
I've got the 300T updated now with the free 2009 map update from Garmin, added some POI's from here and I've got the GTM12 neatly tucked away (and working very well - I regularly get 80+ alerts evert trip).
I'll hang on to it, for the price it does the job for me and is 5 times quicker turning on and picking up satellites than my old Navigon PDA set up.
I only asked the question originally in case the software was a lot diferent but I don't think it is. The only bit I did prefer was the font used for the streetnames looked better on the 205, not sure if thats anything I can amend on the 300? |
Chris444 Lifetime Member
Posted: Fri Jan 02, 2009 2:01 pm Post subject: |
One thing to bear in mind is that the 300 is supplied with a carry case and also a USB lead which you would have to pay extra for with the 205.
Both have just the UK and Ireland maps. Check which version the 300 has by going to serttings-map-map info. If it has been supplied with the 2008 maps it is worth registering the unit on the Garmin web site because you will be entitled to a 2009 map update.
The downloaded update will only update the maps in the unit so go for the option of a cd which includes all the Europe maps as well. It cost me £5.87 inc postage. A 2gb sd card cost about £3 from Amazon. You can then update the unit to the latest UK maps and also transfer the europe maps to the sd card. If the 300 already has the 2009 mapping then the choice is harder. |
Posted: Fri Jan 02, 2009 2:10 pm Post subject: |
Sorry, I started to write the above reply before I saw your latest post but got called away from the computer in the middle of it.
I think that you have made the best choice. |
Posted: Fri Jan 02, 2009 5:08 pm Post subject: |
Thanks for the info guys. I'll register and get the map updates :o)
Yes, this unit is far superior to my old shinco which took ages to find the satellites sometimes.
There are some aspects of the Destinator software that are better e.g. you could programme it to alert you 800 yards and 200 yards from speed cameras whereas this one only appears to allow 1 alert per camera ... or have i got this wrong?
Thanks again, very happy with my purchase! |
Posted: Fri Jan 02, 2009 7:58 pm Post subject: |
Chris444 wrote: | One thing to bear in mind is that the 300 is supplied with a carry case and also a USB lead which you would have to pay extra for with the 205.
Cheers Chris. I'd already opted for the download version of the maps,
I was going to ask if there is anyway of transferring them to SD now so I could get the rest of europe, or, do you know if I can get back to Garmin and request a cd instead? |
Posted: Fri Jan 02, 2009 9:21 pm Post subject: |
Hi dio
When you downloaded the maps I assumed that on the 300 it would only be possible to download the UK maps but are you saying that you managed to download all of Europe to your pc?
The cd came with MapSource which I used to transfer the Europe maps to sd card. I believe that you can also download Mapsource from the Garmin site.
Garmin are always very helpful so if you want the cd try their support line on 0808 2380000
Regards Chris |
Posted: Sat Jan 03, 2009 12:52 am Post subject: |
Chris444 wrote: | Hi dio
Regards Chris |
When I downloaded the file (2.5gb!) it asked me which region I wanted to install to the 300 and gave me a list to pick from. I've got Mapsource and the map for Europe but I don't know how to get the info on to SD card (s), if it is possible at all. |
Posted: Sat Jan 03, 2009 1:58 am Post subject: |
dio wrote: |
Hi dio,
I did the same and it updated the existing maps i.e. UK and Ireland. It also installed all the other European maps which I can view using the Mapsource utility.
In addition, it installed a utility called mapinstall which allows you to select regions of the European maps and install them on the device. You can choose to install them on the Nuvi or on the SD card via the dropdown menu. I installed the Algarve and the Canary Islands. Works a treat
On a different subject, my unit is working really well. I used the trafficmaster data tonight and it rerouted me round a jam on the M60
The only thing that I was disappointed with was the alerts for the cameras, they were very quiet. I've now downloaded the voice alert mp3s and updated my custom POIs so hopefully all will be good next time.
I have searched the forums for tips for the 300T but there doesn't seem to be much on there. Maybe we can use this thread to share things as we discover them?
Happy motoring in 2009 |
Posted: Sat Jan 03, 2009 1:50 pm Post subject: |
McGoo wrote: | dio wrote: |
Hi dio,
Ah, found it now Just exporting France ready for holidays this year.
I'm feeling happier with the unit now, tried out the detour button as I got to the back of a long queue of cars and it got me round to another route.
I'll update on here as I use it, speak to you soon! |
Posted: Sat Jan 03, 2009 5:04 pm Post subject: |
dio wrote: | Ah, found it now Just exporting France ready for holidays this year.
The voice alerts are working well, much better than the default alert. I'm toying with using the Ash Camera Manager, but the standard POI Loader seems to work just fine with the POI files and voices available on pocketGPSWorld. Did you try the Camera Manager? Does it give you much more?
I must say that I am amazed with the value for money that we have with this unit. My last SatNav, a Shinco GM400-EU, cost me £150 exactly two years ago. It had out of date UK maps, no traffic updates and no European maps. It was also a pain to update the cameras as it all had to be done manually.
When you consider the cost of the European maps alone, the Nuvi 300T with European maps and lifetime UK traffic updates is an absolute steal at £88!
Posted: Sat Jan 03, 2009 5:47 pm Post subject: |
McGoo wrote: | dio wrote: | Ah, found it now Just exporting France ready for holidays this year.
I've not tried anything other than the Garmin camera option, will try the one on here soon.
One thing that is puzzling me. I can specify to route to any destinations in Europe even though only UK and Ireland is loaded - does anyone know if this is correct? Would the unit stop working once across the channel? |
