Pocket GPS World :: View topic - 3d recording to avi not working on Vista
docdoc
PostPosted: Thu Jan 01, 2009 12:49 pm    Post subject: 3d recording to avi not working on Vista Reply with quote
I've just got a new PC with Vista - I've installed Memory Map, which seems to work completely fine apart from the avi recording in 3d world view doesn't work. It seems to record but when I view the resulting avi file it's just a blank white screen with "Created with Memory Map" in the corner.
Presumably this is something to do with the way Vista runs different layers of video. I'll try adjusting my video settings and see if I can get it to work, but if anyone has any suggestions I'd be grateful.
My Video card is an ATI Radeon HD 3450.
PostPosted: Thu Jan 01, 2009 1:22 pm    Post subject: Reply with quote
I have exactly the same with my main PC running Vista graphics card is an NVidia GeForce 8600 GTS - although this is not a feature I use within Memory Map so I haven't noticed this until you posted - Mike
docdoc
PostPosted: Fri Jan 02, 2009 8:48 pm    Post subject: Reply with quote
I've not been able to get this to work, but I have found a workaround of sorts if anybody else has similar problems.
There is a program called Debut Video Capture which can be obtained from the website below. It will record whatever is on the screen in avi format (much better compression than Memory Map - a 1 minute route flythrough I recorded took up 22MB as opposed to 1.05GB on my previous XP machine). Works fine with Memory Map.
http://www.nchsoftware.com/capture/index.html
