garcor Regular Visitor
Joined: Feb 10, 2008 Posts: 114 Location: Nova Scotia & Florida in Winter Go 920 App 8.351 Maps NA 850 & C/W EU 830
Posted: Sat Dec 27, 2008 7:09 pm Post subject: |
AndyVaughan wrote: | Mike,
Been away for a few days as you know - I ran 8.204 and as usual it was faultless.
I am loading 8.320 now - I will let you know how it goes over the next week or so.
At least we have Gas back on in Rossendale now!
Andy |
Andy when you try this would you mind trying the FM radio for playing MP3's and audiobooks as well please.
Gary _________________ Go 920
App 8.35N/A Map 8.50
8GB SDHC card 8.30 C/W EU. |
Posted: Sat Dec 27, 2008 7:16 pm Post subject: |
FM Tx works fine for music, I did check this before switching to the Bluetooth link as I prefer this method for sound transfer, I don't use Audio Books so I cannot check that although if the sound from the mp3 player is OK the audio books should be fine - Mike |
Posted: Sat Dec 27, 2008 7:22 pm Post subject: |
mikealder wrote: | FM Tx works fine for music, I did check this before switching to the Bluetooth link as I prefer this method for sound transfer, I don't use Audio Books so I cannot check that although if the sound from the mp3 player is OK the audio books should be fine - Mike |
Thanks Mike I would say you are 100% correct if FM radio works with MP3's it should work with audio books.
Perhaps I will try it again I tried the 8.240 and all worked great other the the FM so perhaps this will work 100% Big on the perhaps . |
Posted: Sat Dec 27, 2008 7:38 pm Post subject: |
garcor wrote: | Perhaps I will try it again I tried the 8.240 and all worked great other the the FM so perhaps this will work 100% Big on the perhaps . | The big difference here is the 8,320 Navcore is intended for use with the x20/ x30 devices, the x40 software is not supposed to be used with the x20/ x30 units and therefore only works with reduced capability - Mike |
Posted: Sat Dec 27, 2008 8:01 pm Post subject: |
mikealder wrote: | garcor wrote: | Perhaps I will try it again I tried the 8.240 and all worked great other the the FM so perhaps this will work 100% Big on the perhaps . | The big difference here is the 8,320 Navcore is intended for use with the x20/ x30 devices, the x40 software is not supposed to be used with the x20/ x30 units and therefore only works with reduced capability - Mike |
Thanks again Mike I just installed it and trying it with route demo all seems very well so far.
I used the loquendo file that I had with the 8.204 with all the Computer voices in it.
By the way complements to the season to you & yours
Gary |
Posted: Sun Dec 28, 2008 9:05 pm Post subject: |
Just gave it a short road trip and all is working well including FM radio for MPS3 & Audiobooks and no stuttering with Dave USA |
Tomtom520 Occasional Visitor
Posted: Mon Dec 29, 2008 1:55 am Post subject: |
Well the 8.320 (9901) works for me on everything as far as I can see, apart from the Kate voice which I cant seem to get to work. Simon works ok though, no stutters or lag.
The only other thing I have noticed is that I now get a voice telling me my arrival time and that there is no quicker route available (No I haven't the traffic ariel plugged in) . It may be in the map as I haven't used the 815 before.
Cheers Keith |
Posted: Mon Dec 29, 2008 3:26 pm Post subject: |
Hi Mike
Is this an official TomTom release or a hacked version of 8.30?
I am not complaining as it seems to work great and I do have all computer voices working so far without stuttering. No lag, and FM for MP3 & audio books worked fine.
I don't have traffic so can't comment on this.
The reason I ask if it is a hacked version is that TomTom Home gives me an Error message only when I try to operate my GO in Home.
It states there is no support for this App.
GPS & Mapshare updates and downloads work fine
I don't need to operate my GO in home that often but I need it to save ITN files created with Houghi or waypoints with MapPinner
Gary
P.S.This is the Loquendo file that I am using
http://www.megaupload.com/?d=NNHZ647O |
Posted: Mon Dec 29, 2008 3:42 pm Post subject: |
When I put the links in the earlier post to the application I have found works better than others I did say it was intended for the x20/ x30 using TomTom Work - so I guess it is an official Navcore but not one we should be using if we don't have the Work system/ software and hardware, it isn't a hacked version as it downloads from TomTom's server - I don't use Home very much so I don't miss that - what I do like is a decent screen refresh rate and no stuttering - Mike |
Posted: Mon Dec 29, 2008 4:38 pm Post subject: |
mikealder wrote: | When I put the links in the earlier post to the application I have found works better than others I did say it was intended for the x20/ x30 using TomTom Work - so I guess it is an official Navcore but not one we should be using if we don't have the Work system/ software and hardware, it isn't a hacked version as it downloads from TomTom's server - I don't use Home very much so I don't miss that - what I do like is a decent screen refresh rate and no stuttering - Mike |
Thanks Mike
As I said everythings works great except opperate my Go in home and that isn't a big deal.
I made a misquote in privous post I said Houghi needs home to operate.
It doesn't .
Only Mappiner or sending W/P from Google Maps to GPS does and that isn't a big deal at all.
scotch_whisky Occasional Visitor
Posted: Thu Jan 01, 2009 1:12 pm Post subject: |
I've been using v8.204 with my 520 for a couple of weeks with absolutely no problems. I decided to give v8.320 a go however, following Mike's post, and can report that after about 500 miles I have had no problems. I would say that the performance is the same or very similar to v8.204.
GPRS and the light sensor both work, they didn't with v8.204, so I think this is the way to go. You don't get the new icons but there is nothing wrong with the old style anyway.
Can't see why TomTom are dragging their feet on this one. |
thetrotter Regular Visitor
Posted: Thu Jan 01, 2009 4:01 pm Post subject: |
Mike, just one question - in 2 halves!
why did you give separate links for the 8.320 download for x20 and x30 users? Just curious, as it's the same software what does it matter?
D. _________________ TT Go 920T
Navcore: APP 8.393 WORKS.
Map: Western Europe v845.2645
PGPSWorld Speed Camera Database (naturally)
Posted: Thu Jan 01, 2009 4:13 pm Post subject: |
I gave out two links for the Navcore 8,320 as this is how the Home software downloads it.
I have no idea if there is a difference between the contents of the two downloads, at face value they do indeed look to be the same.
There could be minor changes within the file contents whilst keeping the file size the same so you don't spot the difference using Windows Explorer you could compare the contents of each file with a hex editor (or similar) to see if there are any such differences - Mike |
DJ-Power Occasional Visitor
Posted: Thu Jan 01, 2009 9:37 pm Post subject: |
I tried this out on my 720 taking a usual trip to Paris from London and found all worked smoothly. My gprs seemed to be working as I got the green dot but none of my speed cameras showed up or warned me they were there.
I use the tom tom cameras and they just did not work at all, any ideas?
I had to roll back to a backup of V8.3 with my 8.15 map and that gave me the cameras back but now I have the map lag again.
Regards
DJP  |
Hoppy Regular Visitor
Posted: Fri Jan 02, 2009 12:44 pm Post subject: |
I tried the software out on my 520T on a quick 120 mile round trip and I'm pleased to say it all worked great.
I had FM Transmit working, connected to phone, remote control working, traffic connected all at the same time no jane stutter no lag and no flashing screen. Fantastic.
Thanks Mike _________________ TomTom Go 950 Live.
App 9.054
Europe v8.50
NA 2GB v8.45 |
