john_d1974 Occasional Visitor
Posted: Sat Dec 20, 2008 8:59 pm Post subject: no gps signal |
one xl
was fine this morning, then 2night i turned it on for 2 hours but still couldnt get a signal,
connected to tt home, got the gps fix update, still cant get a signal, reset it but its stil the same,
any idea whats going on? |
Posted: Sat Dec 20, 2008 9:09 pm Post subject: update |
using tt home, if i click on the "operate my one xl" it then appears to have found the satellites, if i then disconnect the xl (without disturbing it postition) and check it then tells me their is no reception |
Posted: Sat Dec 20, 2008 9:10 pm Post subject: |
Take it outside for 15 minutes switched on and see if it can get a signal, don't go off what the unit displays while connected to Home, it won't be anything like accurate - Mike |
alanji Lifetime Member
Posted: Sun Dec 21, 2008 4:45 pm Post subject: |
mikealder wrote: | Take it outside for 15 minutes switched on and see if it can get a signal, don't go off what the unit displays while connected to Home, it won't be anything like accurate - Mike |
When operating through Home you set your current location to wherever you want (very useful for itinerary planning not starting from your current location). It does not use a gps fix. _________________ Alan
Go 750 LIVE Europe Map 870.3406
Go 720 W Europe Map 865.3245
One XL W Europe. Map 715.1689
Dell Axim & TT3
Psion 5mx & Routeplanner |
