Pocket GPS World :: View topic - Dr Nightmare Voice, problem?
kk99ll
PostPosted: Sun Dec 14, 2008 2:09 pm    Post subject: Dr Nightmare Voice, problem? Reply with quote
Hi Guys.
I downloaded this on to my nuvi 200, ,checked using the PC to see if it was in the proper folder and it shows up OK, but it's not showing up on the unit's screen, under voices.
Any idea's why not Question
thanks in advance
"Gort...Klaatu barada nikto"
kk99ll
PostPosted: Mon Dec 15, 2008 6:09 pm    Post subject: Reply with quote
bump..
Anybody Question
PaulB2005
PostPosted: Mon Dec 15, 2008 6:36 pm    Post subject: Reply with quote
Did you unzip the file and copy the conents to the Nuvi?
You should see a file called DrNightmare.vpm in the x:\garmin\voices folder, not DrNightmare.zip
kk99ll
PostPosted: Mon Dec 15, 2008 7:03 pm    Post subject: Reply with quote
Yes, it's installed (DrNightmare.vpm) it just doesn't show up on the screen Confused
StuartStrangeboy
PostPosted: Tue Dec 16, 2008 11:25 am    Post subject: Reply with quote
Do you have the latest software installed on your 200? Use the web updater to update your device, this is quite common as you need the latest software to run new voices.
kk99ll
PostPosted: Tue Dec 16, 2008 5:11 pm    Post subject: Reply with quote
Don't think there is any new updates for the 200?, were do I look.
as you can see from the pic, it's in there, wonder if you need to delete some of the foreign languages, so to free up more space Question
http://i238.photobucket.com/albums/ff78/kk99ll/iviewcapture_date_16_12_2008_time_1.jpg
IMG Tags replaced with URL Tags. Please don't post images wider than 450 pixels as per the forum rules. PaulB2005
PaulB2005
PostPosted: Tue Dec 16, 2008 5:20 pm    Post subject: Reply with quote
You need to download and install WebUpdater to your PC. Plug in the Garmin and run the program to check the software is up to date. It'll tell you all the updates that are available and will let you install them.
Tip: Make sure the unit has a good charge before you use it because once the downloads are installed you need to restart the unit to finish the update. this can take a bit of time. Do NOT turn the unit off even if it looks frozen, just give it time.
kk99ll
PostPosted: Tue Dec 16, 2008 5:28 pm    Post subject: Reply with quote
Thanks, I'll give it a go, (sorry about the pic,should have read the rules Embarassed )
BTW I thought the unit got the power from the usb socket, when the unit was plugged into the PC Question
PaulB2005
PostPosted: Tue Dec 16, 2008 5:32 pm    Post subject: Reply with quote
Yes it does, but in order to restart the unit I normally disconnect the USB lead to get it to shut down and restart. Never tried using the on / off switch to cycle the power..... Always forget....
kk99ll
PostPosted: Tue Dec 16, 2008 7:26 pm    Post subject: Reply with quote
Many thanks for your help, all sorted Thumbs Up
23.015 (29 Jan 25)
