kk99ll Occasional Visitor
Posted: Sun Dec 14, 2008 2:09 pm Post subject: Dr Nightmare Voice, problem? |
Hi Guys.
I downloaded this on to my nuvi 200, ,checked using the PC to see if it was in the proper folder and it shows up OK, but it's not showing up on the unit's screen, under voices.
Any idea's why not
thanks in advance _________________ "Gort...Klaatu barada nikto"
Posted: Mon Dec 15, 2008 6:09 pm Post subject: |
bump..
Anybody _________________ "Gort...Klaatu barada nikto"
Posted: Mon Dec 15, 2008 6:36 pm Post subject: |
Did you unzip the file and copy the conents to the Nuvi?
You should see a file called DrNightmare.vpm in the x:\garmin\voices folder, not DrNightmare.zip |
Posted: Mon Dec 15, 2008 7:03 pm Post subject: |
Yes, it's installed (DrNightmare.vpm) it just doesn't show up on the screen _________________ "Gort...Klaatu barada nikto"
StuartStrangeboy Regular Visitor
Posted: Tue Dec 16, 2008 11:25 am Post subject: |
Do you have the latest software installed on your 200? Use the web updater to update your device, this is quite common as you need the latest software to run new voices. |
Posted: Tue Dec 16, 2008 5:11 pm Post subject: |
Don't think there is any new updates for the 200?, were do I look.
as you can see from the pic, it's in there, wonder if you need to delete some of the foreign languages, so to free up more space
http://i238.photobucket.com/albums/ff78/kk99ll/iviewcapture_date_16_12_2008_time_1.jpg
IMG Tags replaced with URL Tags. Please don't post images wider than 450 pixels as per the forum rules. PaulB2005 _________________ "Gort...Klaatu barada nikto"
Posted: Tue Dec 16, 2008 5:20 pm Post subject: |
You need to download and install WebUpdater to your PC. Plug in the Garmin and run the program to check the software is up to date. It'll tell you all the updates that are available and will let you install them.
Tip: Make sure the unit has a good charge before you use it because once the downloads are installed you need to restart the unit to finish the update. this can take a bit of time. Do NOT turn the unit off even if it looks frozen, just give it time. |
Posted: Tue Dec 16, 2008 5:28 pm Post subject: |
Thanks, I'll give it a go, (sorry about the pic,should have read the rules )
BTW I thought the unit got the power from the usb socket, when the unit was plugged into the PC _________________ "Gort...Klaatu barada nikto"
Posted: Tue Dec 16, 2008 5:32 pm Post subject: |
Yes it does, but in order to restart the unit I normally disconnect the USB lead to get it to shut down and restart. Never tried using the on / off switch to cycle the power..... Always forget.... |
Posted: Tue Dec 16, 2008 7:26 pm Post subject: |
Many thanks for your help, all sorted _________________ "Gort...Klaatu barada nikto"
