rebluc Occasional Visitor
Posted: Fri Dec 12, 2008 7:26 pm Post subject: GO 530 Sound Problems. |
I recently purchased a 530 2 months ago, that worked fine. Since updating to App 8.300 & Map v815.2003 I now suffer problems when I set volume above 85%. The speaker seems to struggle causing distorted voice and the screen flickers with voice instructions.
I've read other posts and rolled back my App & map and this then doesn't happen. I really want to run up to date maps etc. Anyone help? |
MrT Frequent Visitor
Joined: Nov 14, 2003 Posts: 2146 Location: Surrounded by A1, M1 & M25
Posted: Fri Dec 12, 2008 7:36 pm Post subject: |
Why not have the volume below 85%, with 8.3 above this is way too loud for me? _________________ Drivelux |
Posted: Fri Dec 12, 2008 7:38 pm Post subject: |
At the moment there is nothing that can be done to get around this issue 100% so I would sit tight and await an update to the Navcore software to address these issues.
Some users have been swapping the TTS voice files as a way around the stuttering speech, but this won't help with the 530 as it will have been supplied with the latest standard of TTS files installed.
Wait for the update and continue to use the device running the 8,010 and v810 map for the time being - Mike |
Posted: Fri Dec 12, 2008 7:46 pm Post subject: |
MrT wrote: | Why not have the volume below 85%, with 8.3 above this is way too loud for me? |
Currently running with the volume at 85% and find it quite loud enough myself. Just didn't know if the screen brightening/dimming to the pattern of a distorted voice was a speaker problem or software issue. |
Andy_P Pocket GPS Moderator
Posted: Fri Dec 12, 2008 10:28 pm Post subject: |
You should find the problem goes away if you use the charging lead to power the Go.
The internal battery cannot provide the instantaneous current needed once it has started to run down. |
