TELREA Lifetime Member
Posted: Thu Dec 04, 2008 9:32 pm Post subject: New Navcore 8.204... |
hi all have a 720 running 8.3 seem to be having the usual probs and seen a few links for ver 8.203 but i see there is a 8.204 anyone have a link to this as i fancy trying this out to see if it fixes my refresh rate probs for one:) thanks in advance
TEL. |
Posted: Thu Dec 04, 2008 9:39 pm Post subject: |
According to TomTom it's for the x40 range ONLY and offers
Quote: | Version 8.204
(TomTom GO x40 only)
Minor improvements |
Posted: Thu Dec 04, 2008 9:47 pm Post subject: |
no bother just having a look around a few posts alot of peeps are running this on a 520/720 |
Posted: Thu Dec 04, 2008 9:57 pm Post subject: |
I would just wait a while for a new release to address the problems you have with 8,300 - no idea when it might be made available, but rather than mess up your device I would wait for a bit.
If you do try running the x40 software on your device returning the unit back to what it should be running could take a few hours depending upon your PC connectivity - Mike |
cutslick Occasional Visitor
Posted: Fri Dec 05, 2008 1:10 pm Post subject: |
TELREA if you do want to give it a try make sure you do a full back of your current configuration with Windows Explorer first. Having said all that I can testify that it works very well indeed on my 920T and I will not be going back to 8.300 or 8.010 for that matter
Oh and here is the link to 8.204 that you were looking for
http://download.tomtom.com/sweet/navcore/navcore_8.204.9718.go940.cab _________________ Garmin 3490 LMT
TT Go 920T |
Devastator Occasional Visitor
Posted: Fri Dec 05, 2008 1:35 pm Post subject: |
cutslick wrote: | TELREA if you do want to give it a try make sure you do a full back of your current configuration with Windows Explorer first. Having said all that I can testify that it works very well indeed on my 920T and I will not be going back to 8.300 or 8.010 for that matter
http://download.tomtom.com/sweet/navcore/navcore_8.204.9718.go940.cab |
Is that link OK for the 720 or only the 920? |
Posted: Fri Dec 05, 2008 1:51 pm Post subject: |
Devastator wrote: | Is that link OK for the 720 or only the 920? |
A good few have it running on successfully 720s so you should be OK, make sure you back up first though (sound like an old record don't I).
The other point is you may want to consider using V7 voices, a quick search on this forum should find you the links to the correct CAB files. _________________ Garmin 3490 LMT
TT Go 920T |
Posted: Fri Dec 05, 2008 2:04 pm Post subject: |
cutslick wrote: | Devastator wrote: | Is that link OK for the 720 or only the 920? |
The other point is you may want to consider using V7 voices, a quick search on this forum should find you the links to the correct CAB files. |
Cheers appreciate the help and quick reply. Will back up and then hunt down those V7 voiices 1st.  |
Posted: Fri Dec 05, 2008 5:57 pm Post subject: |
I can't be very good at looking or not finding the right link.
Do you have a link to the V7 or V7.1 Voice files? |
Posted: Fri Dec 05, 2008 6:20 pm Post subject: |
There are links to V7 voices in the 'voice problem after 8.3 on 720' thread, go to page 25, 2nd post down. The instructions there are useful too. _________________ Garmin 3490 LMT
TT Go 920T |
Posted: Fri Dec 05, 2008 7:11 pm Post subject: |
cheers cutslick for the replies will grab this now and have a tinker later,i only use jane on the TT would i still need to grab other voices? |
wazzzzupmate Regular Visitor
Posted: Fri Dec 05, 2008 8:56 pm Post subject: |
I have run 8.204 on my 730 this week because I thought it was worth a try after using the buggy 8.3. I can report that over a few thousand miles the device never crashed or locked up. The RDS TMC worked ok but not the GPRS traffic. GPRS worked for weather and quickfix. It still tahes a long time to calculate a route of about 240 miles, and making a wrong turn at the start of the routes requires parking up whilst the device calculates the new route. The refresh rate seems better with 8.204.
I will restore my 8.3 backup for now as I like the GPRS traffic. _________________ -------------------------
Tomtom Go 400
Tomtom 1.15.1 for Iphone |
Posted: Fri Dec 05, 2008 9:43 pm Post subject: |
I take it that if i install this new navcore i will have a traffic bar constantly down the side of the tomtom is this correct?Just trying to suss this out before i do something stupid |
dhn Frequent Visitor
Posted: Fri Dec 05, 2008 9:53 pm Post subject: |
That is correct. No way to remove it. Discussed here _________________ David |
Posted: Fri Dec 05, 2008 10:15 pm Post subject: |
TELREA wrote: | I take it that if i install this new navcore i will have a traffic bar constantly down the side of the tomtom is this correct?Just trying to suss this out before i do something stupid |
TELREA I notice you have a x20 device. With my 920T I only see the traffic bar on the right hand side IF I have my RDS-TMC antenna plugged in. Take it out and the traffic bar disappears. So no problems there, I'm sure your 720 would be the same. _________________ Garmin 3490 LMT
TT Go 920T |
