Pocket GPS World :: View topic - hard wire imformation please
bullmastifkyle
PostPosted: Wed Dec 03, 2008 9:09 pm    Post subject: hard wire imformation please Reply with quote
Hi people
I am new to this forum so please forgive me if i,m in the wrong area . I have just purchased a new go 530t . I would like to know is it possible to hard wire this rather than using the cig connection . I have looked through the forum to find it very interesting and help full but i didn't manage to see anything about hard wire connections .
thanks to every one who helps
MrT
PostPosted: Wed Dec 03, 2008 10:04 pm    Post subject: Reply with quote
Most modern TT units take 5V so need a DC-DC convertor to connect into a car system, the x 30 range needs a standard 5V mini usb. There are quite a few mobile phone hard wire kits around that offer this but they are needlessly expensive.
For hardwiring a car, the simplest option is to buy a cigarette lighter extension trailing lead type socket either as a socket or by an extension and cut the plug off and hardwire that into the car then put the TT car adaptor or any suitable cigarette lighter based lead into this and take the other end to your unit.
As this will be out of sight, it is just as good as a commercial hardwired system. The 12V/5V conversion is carried out in the lead plug which usually also contains a fuse. If it is a lower quality plug or lead you can always lock the plug and socket together with a bit of tape. It sounds crude, but it is just as good as any other hard wired system.
PostPosted: Wed Dec 03, 2008 10:20 pm    Post subject: Reply with quote
Just don't cut off the cigarette plug and wire direct into 12v, if you do you WILL fry your Tomtom!
bullmastifkyle
PostPosted: Wed Dec 03, 2008 10:42 pm    Post subject: Reply with quote
Thanks Mrt and darren for your help will go for the cigarette lighter extension option sound easy enough .
Once again thanks for your help and keep up the good work .
MrT
PostPosted: Wed Dec 03, 2008 11:43 pm    Post subject: Reply with quote
Yes just to clarify my earlier point, you can cut the lead on an extension lead to get a 12V socket, but you must still use the TT lead with the 12V to 5V conversion in the plug as all TT devices work on 5V.
DO NOT CUT THE TT SUPPLIED LEAD AND HARDWIRE IT AS THE CIGARETTE LIGHTER PLUG ON THIS CONTAINS THE 12V TO 5 V CONVERTOR.
PostPosted: Thu Dec 04, 2008 1:34 am    Post subject: Reply with quote
Here's a previous thread about this with some Maplin part numbers
Click me
Sean16v
PostPosted: Thu Dec 04, 2008 9:10 am    Post subject: Reply with quote
I think this is what you are looking for Very Happy
http://www.buybits.com/product/sku_3110.aspx
mpwilson99
PostPosted: Thu Dec 04, 2008 10:27 am    Post subject: Reply with quote
This is something which I need to get sorted for a new motor im getting!
I would like to do the wiring myself this time rather then Halfords!
I like the idea of using one simple lead, from the buybits site, rather then my current setup of an extra cig lighter behind the dash, however I am a bit confused on where that open piece of wire should be placed, any ideas?
Thanks!
MPW
PostPosted: Thu Dec 04, 2008 10:29 am    Post subject: Reply with quote
Probbly, but as MrT said above, needlessly expensive, especially when compared with the above solutions Very Happy .
MrT
PostPosted: Thu Dec 04, 2008 11:25 am    Post subject: Reply with quote
On cables like the buybits one you have to be careful about the orientation of the mini USB plug.
On the one they show in the picture where the cable is perpendicular to and on the longer face of the mini USB plug it would not fit the X40 active mount as the cable entry part of the plug would catch on the upper body of the mount and it would not fully insert. The x40 mount needs a sideways or from the shorter face cable entry.
I know this as the Go530 supplied cable will not fit the Go940
mpwilson99
PostPosted: Fri Dec 05, 2008 8:58 am    Post subject: Reply with quote
The buybits cable mini usb plug looks exactly the same as I have now, so for me personally its not an issue.
The only thing I need to know is where that bear wire sticks into!
Any ideas on where I stick it!
Many Thanks
MPW
PostPosted: Fri Dec 05, 2008 9:06 am    Post subject: Reply with quote
The easy option is to attach the wires to the back of the existing ciggy socket, this way you know its fused and they are generally easy to get at without tearing the car apart.
Just a word of caution though, if the car is equipped with air bags take great care when messing around inside the dashboard, if you set one off you could end up with a hospital trip and a very expensive repair - Mike
22.055 (29 May 24)
