IanS100 Frequent Visitor
Posted: Mon Dec 01, 2008 1:35 pm Post subject: |
chelsky wrote: | Hi Through this thread I have installed ver.8.204 to my map 815.2003. I also deleted the contents of my loquendo folder and copied over the ver. 7 voices of Kate and Simon. Checked my loquendo folder and voice folder and they are both in there. The problem is, when I switch on TT the only voice options I have are Tim, Jane, Kathy and Sean. Does anybody know what I have done wrong please.
chelsky |
I did pretty much the same & got no voice, despite having copied Kate & Simon across just as you did. When I checked on voice downloads within home neither voice was showing up as being installed on my 520 so I deleted them with explorer & selected/downloaded them again via home after which all worked ok |
chelsky Regular Visitor
Posted: Mon Dec 01, 2008 3:09 pm Post subject: |
Still no joy. I have tried so many combinations. If I can't fix it soon, I will have to format and reinstall 815 ver.8.3 |
AlandEi Regular Visitor
Joined: Aug 18, 2008 Posts: 82 Location: North Wales UK
Posted: Mon Dec 01, 2008 3:39 pm Post subject: |
Don't know whether it has a bearing on your problems Guys, but the Loquendo TTS7 file I downloaded from AndyVaughn's link only contained the "Kate" computer voice in the "Voices" folder,... not Kate and Simon... and Kate is working fine on mine.
Alan. _________________ Tom Tom Go 520 - Map UK ROI 720.1803 Navcore_8.204.9718.go40 - ( Loquendo TTS7 ) / RDS-TMC /Tyre... purchased the Go mainly for the itinerary feature |
cutslick Occasional Visitor
Posted: Mon Dec 01, 2008 3:57 pm Post subject: |
Yes I'm pretty sure that's the file I'm using, just Kate's voice. All works fine (thankfully) _________________ Garmin 3490 LMT
TT Go 920T |
Posted: Mon Dec 01, 2008 4:35 pm Post subject: |
Thanks for the responce. Will remove the loquento file and replace with Andys and let you know the result. |
Posted: Mon Dec 01, 2008 6:06 pm Post subject: |
That didn't work So what I did was to reinstall from a back up ver.8.204. Job sorted, now have Kate as one of the options
Question. Is it possible to have Simon as well? |
Posted: Mon Dec 01, 2008 7:05 pm Post subject: |
chelsky wrote: | That didn't work So what I did was to reinstall from a back up ver.8.204. Job sorted, now have Kate as one of the options
I have both Kate & Simon installed & both work. |
AndyVaughan Lifetime Member
Joined: Apr 13, 2006 Posts: 1500 Location: Rossendale
Posted: Mon Dec 01, 2008 7:32 pm Post subject: |
Try this - put the LoquendoTTS folder back on the device with the v6 voices.
Connect to HOME and then remove all Computer voices.
Now download just the Kate TTS7 voice and use WINRAR to extract this straight on to the device - it will put all of the files in the LoquendoTTS folder, you just need to ensure that you extract to the drive letter that your TT is.
Also, did you delete the LoquendoTTS folder after installing 8.3?
If so you will have deleted 2 files that the Navcore install puts in the LoquendoTTS folder - try reinstalling 8.3 again and it will put them back.
I would try the second option first!
Andy |
Posted: Mon Dec 01, 2008 9:58 pm Post subject: |
Hi Andy. Thanks for the sugestions. To be honest, I don't know what I have done!!! I have deleted loquendo, reinstalled it, added to it. Finally, I reinstalled ver.8.204 with my map815.2003. I now have the loquendo that comes with that version 8.204 with kate.
Is there not an easy way to install simon? now that everything is back to "normal" If not, I will stick with Kate. I just don't fancy removing, reinstalling etc. again.
David |
Posted: Mon Dec 01, 2008 10:07 pm Post subject: |
It will have been the reinstall of 8.204 that fixed it as the missing files from the bin and lib subfolders willl have been reinstated.
I am sure someone pasted a link to Simon on the TT servers in one of the other threads - problem is there are so many posts to wade through it is difficult to make sense of it all.
Andy |
Posted: Mon Dec 01, 2008 10:18 pm Post subject: |
AndyVaughan wrote: | I am sure someone pasted a link to Simon on the TT servers in one of the other threads - problem is there are so many posts to wade through it is difficult to make sense of it all. |
Have a look at the post made by "Infama" in This Thread you should find the link to what you want - Mike |
Posted: Mon Dec 01, 2008 10:20 pm Post subject: |
mikealder wrote: | AndyVaughan wrote: | I am sure someone pasted a link to Simon on the TT servers in one of the other threads - problem is there are so many posts to wade through it is difficult to make sense of it all. |
Or just click HERE |
Posted: Mon Dec 01, 2008 11:16 pm Post subject: |
Brilliant
Thank you all so much Now have both on my TT
David |
Posted: Tue Dec 02, 2008 10:39 am Post subject: |
After arriving home last night I decided to double check that all the installed voices were working so I went into voices & selected / tested each one & all was ok. I then planned a route, used demo & found that all voices had gone, nada, zip, nothing – no spoken instructions at all. Back into change voices & I now got no sound at all when I selected ‘Test’.
Step 1. I delete & reinstall Kate & Simon through home – still nothing.
Step 2. Install backup copy of Loquendo but this didn’t help either, still no voices.
Step 3. Delete everything & copy complete working backup to 520 & all voices return..
This suggests to me that the voice failure isn’t so much associated with the Loquendo as a configuration setting somewhere that was changed when I messed with voice selection & stopped it all working.
One other thing I have with x40 is that I need to keep resetting the 520. About every third switch on it fails & keeps switching off again almost immediately. After the reset it shows the TomTom Home disconnect screen with moving blue line at the bottom after which the 520 works ok again until the next time it happens |
Posted: Tue Dec 02, 2008 10:44 am Post subject: |
Took my wife to work this morning. short run, only 3 miles each way and no problems with Simon
David |
