Pocket GPS World :: View topic - How does TT know which day it is?
navtrav
PostPosted: Mon Dec 01, 2008 11:42 am    Post subject: How does TT know which day it is? Reply with quote
I have Go 730, latest maps & software.
The IQ route planning is highly trumpeted as a way to avoid rush-hour blackspots etc.
But, as there is no calendar in the thing, how does it know when I set off whether it's a sleepy Sunday morning or a hectic Monday morning?
Yes, it can see the time, although my internal clock seems to keep re-setting itself to 12am (another topic!).
So I try 'advance planning'. And yes, you can eventually menu your way to choosing a day. But up pops this ludicrous calendar that only shows 1970-71. While I'd really like to time travel back to then, it is totally irrelevant to my journey today.
So my conclusion is that the IQ planner has a very low IQ. Please tell me I'm wrong and show me the error of my ways. Advice gratefully received.
Tim
PS I did a search in TT forums on IQ but found nothing noting this glaring TT con.
norm2002
PostPosted: Mon Dec 01, 2008 11:49 am    Post subject: Reply with quote
I believe it is just that, when the TT gets a full GPS fix, it gets the time AND DATE from the satellites.
After a hard reset you may have to tell it the offset from the standard time it uses. Not sure what this is as it seems to be something like PST on mine.
navtrav
PostPosted: Mon Dec 01, 2008 11:59 am    Post subject: Reply with quote
Thanks norm2002. So I guess the satellites know which time zone (eg Paris/London?) that I'm in by the fix on my position and thus correct my clock? Is TT software this sophisticated?
garcor
Location: Nova Scotia & Florida in Winter Go 920 App 8.351 Maps NA 850 & C/W EU 830
PostPosted: Mon Dec 01, 2008 12:04 pm    Post subject: Reply with quote
This is something I have wondered as well. Does the time on you unit change automatic from one time zone to the next?
Anita
PostPosted: Mon Dec 01, 2008 12:10 pm    Post subject: Re: How does TT know which day it is? Reply with quote
I don't believe it is another topic.
When I plan a route and select Specific date and time the device shows the current date and time, even before it gets a satellite fix. If yours keeps reverting to 12.00am and 1970/71, even with a satellite fix, there's something wrong. If no one here can suggest anything you'll have to phone TomTom on 0845 161 0009.
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
navtrav
PostPosted: Mon Dec 01, 2008 12:31 pm    Post subject: Reply with quote
Thank you Anita. It seems I'll have to phone TT. (Help lines are my worst nightmare.) Even with a satellite fix I still get the 1970 calendar,
Mind you, having to get a gps fix does negate the value of advance planning as one is very likely to be doing that in a building before setting off.
norm2002
PostPosted: Mon Dec 01, 2008 12:35 pm    Post subject: Reply with quote
As Anita says, once it has got a fix, it should keep the correct time even when it is out of sight of satellites or switched off. The only time when it should lose the time is if it is reset or the battery goes flat. If it happens regularly, you do need to contact TT.
matthewj
PostPosted: Mon Dec 01, 2008 1:07 pm    Post subject: Reply with quote
IME, it remembers the offset that you specify. The GPS satellites say it is 6am, but you set it to 9am, so from then on it just shows the satellite + 3 hours. This is remembered for when you hit the Sync button.
When I went to the USA, I adjusted the time and it remembered for the week, and I then had to change it again back in the UK.
But if it doesn't remember the time at all, you have a faulty unit IMO.
navtrav
PostPosted: Mon Dec 01, 2008 2:19 pm    Post subject: Reply with quote
Thank you everyone. Sorry for late response - blame Virgin Media loss of signal!
Yes, I take it back. Ten minutes after getting the gps fix I was able to get an up-to-date calendar up.
So what you're saying Matthewj, is you still need to reset the clock to get the right 'offset' if you change time zone, which I guess for us Europeans isn't too hard a chore!
I think my TT's reverting to 12am is due to the battery going flat, which I find with this newer model it does very quickly if it's not used for a week or so. My old Go lasted for ages.
mattcu
PostPosted: Mon Dec 01, 2008 3:08 pm    Post subject: Reply with quote
If it's any consolation, I think the time zone offset is likely to be simply a cosmetic measure for your benefit. I'd bet that all IQ2 data would be referenced according to the UTC time, regardless of the country about which that data is stored.
This is certainly how aviation and nautical GPS-derived guidance systems work. Especially so because the two GPS constellations (Navstar, the American one and the one which most western 'GPS' systems reference, and GLONASS, the Russian one) emit their time signal in UTC format.
I'd bet that TomTom performs its calculations based on UTC - the time the satellites emit, and the time that IQ2 data is (in my speculative opinion) likely referenced to.
For our purposes, UTC is essentially Greenwich Mean Time.
This does, however, introduce one hypothetical questions how does IQ2 adjust the various IQ2 route costs at the start and end of British Summer Time? I'd wager that it probably doesn't...
I also suspect that Advanced Planning tool is somewhat limited. To be perfect, it would rely on the user having the correct time offset entered (for adjusting the 'start journey at...' time to UTC) or will have to approximate the time zone based on the longitude of the start position. Roughly, time zones change every 15° of longitude but this is only an approximation.
As with many areas, I'd love to know how TT actually do it, and how (or even if) they solve these problems.
Calomax
PostPosted: Tue Dec 02, 2008 9:55 am    Post subject: Reply with quote
I only use mine a few times a year but I always keep it in it's dock connected to a USB port. that way it stays fully charged.
TT Go Essential
Skippy
PostPosted: Tue Dec 02, 2008 9:38 pm    Post subject: Re: How does TT know which day it is? Reply with quote
It gets the date and time (to within 0.000001 of a second) from the satellites.
These devices usually have an internal battery to keep the real-time clock running. If this battery is dead then it will lose the clock information until it gets it's next satellite fix.
It also stores other data which helps it get a quicker fix when you switch it on from cold (ie, off for over 12 hours). When you have a clear view of the sky, does your unit take more than about 1 or 2 minutes to get a fix when it's been off for a day or two? If so then this is related to it not knowing the time and date so it can't predict where the satellites are to get a quicker fix.
Gone fishing!
MrT
PostPosted: Thu Mar 12, 2009 12:41 pm    Post subject: Reply with quote
This morning I updated the 530 from Home and it reset the clock and calendar (with a full battery) until it received a satellite signal. The updates were only the usual Cameras, Mapshare and GPS Quickfix.
Drivelux
PostPosted: Fri Mar 13, 2009 1:37 am    Post subject: Reply with quote
What a load of cobblers!
Question - How does TT know which day it is? Answer - TT doesn't know which day it is! TT doesn't know its xx from its yy (substitute your own ideas)!
TT doesn't know an awful lot of stuff, like how to make my two devices do what TT tells me to expect of them.
GerryC
PostPosted: Fri Mar 13, 2009 11:57 am    Post subject: Reply with quote
It's OK Dennis, the TomTom doesn't have a clue what date/time it is or even where it is until the satellites tell it.
Of course, if your devices show different times when sitting next to each other, then [insert own imagination here].
Out of here
Seriously, if I leave mine without a signal for a few days, even when charged, it reset the time to 12:00. I believe this is due to a timeout to prevent the device holding potentially inaccurate data. Once you get a signal lock, it's back to normal.
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
