Taximark Occasional Visitor
Posted: Tue Nov 25, 2008 1:27 pm Post subject: 720 has gone really slow |
Could it be that i don't have much memory left? i have quite a few voices on it and thought it could be this, if so can how do i delete them? |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Tue Nov 25, 2008 1:49 pm Post subject: Re: 720 has gone really slow |
Taximark wrote: | Could it be that i don't have much memory left? i have quite a few voices on it and thought it could be this, if so can how do i delete them? |
Use Home to remove items from my unit and select the voices you wish removed. _________________ David |
Posted: Tue Nov 25, 2008 3:32 pm Post subject: |
I had about 13 voices on and i've deleted all but 2, now when i go out later to work i'll see if it's cured it, it was so slow last night that it was moving in stages or like block motion. |
Calomax Lifetime Member
![](modules/Forums/images/avatars/10616504774a6a18ca3ea50.jpg)
Joined: Sep 30, 2005 Posts: 988 Location: St Martin's, Guernsey
Posted: Wed Nov 26, 2008 9:58 am Post subject: |
Have you got any POIs enabled to show on the map? If so try it again with them all disabled. _________________ TT Go Essential |
Posted: Wed Nov 26, 2008 3:31 pm Post subject: |
Yes i had a few but have got rid of all but one - the one that were on originally (petrol station sign), i also deleted all the voices and some new poi's i downloaded but it's still slow, now the strange thing is sometimes it goes to the "normal speed (no stage like movement) but seems to go back to slow after a while, really puzzling. |
bullyterrier Regular Visitor
![](modules/Forums/images/avatars/134314511849201ff1f1955.jpg)
Posted: Wed Nov 26, 2008 4:09 pm Post subject: |
Taximark, which application version are you using on your 720? If it's the latest 8.3 then it is probably this causing the problem, there has been many reports of the latest software causing the map to become jerky and the text to speech directions to become interrupted. |
Posted: Wed Nov 26, 2008 5:34 pm Post subject: |
Bullyterrier, it is the 8.3 V i might revert back to 8.10 loads of speed cams missing on 8.3 too. |
Posted: Thu Nov 27, 2008 5:27 pm Post subject: |
Can someone tell me how i go about putting the 8.10 V on as this 8.3 is causing me loads of bother.
I think i have a back up of 8.10 on home. |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Thu Nov 27, 2008 7:28 pm Post subject: |
Taximark wrote: | Can someone tell me how i go about putting the 8.10 V on as this 8.3 is causing me loads of bother. | I detailed how to roll the device back to the v8,010 release in This Thread - Mike |
Posted: Sun Nov 30, 2008 4:08 am Post subject: |
mikealder wrote: | Taximark wrote: | Can someone tell me how i go about putting the 8.10 V on as this 8.3 is causing me loads of bother. | I detailed how to roll the device back to the v8,010 release in This Thread - Mike |
Thanks mike, back on 8.10 and the missing cams are back. |
Posted: Sun Nov 30, 2008 9:27 am Post subject: |
Mark which camera database were you having trouble with the one from TomTom or PocketGPSWorld? and if it was ours do you have any specific examples of missing cameras that we could check up on - Mike |
