Pocket GPS World :: View topic - Car preferences
Car preferences
Goto page Previous  1, 2
norm2002
PostPosted: Sat Nov 29, 2008 10:33 am    Post subject: Reply with quote
uffe73 wrote:
Ok, avoiding low bridges requires a POI list of bridges, but I'm sure TomTom could collect that information easily.
/Ulf
Just like they 'easily' collect the data on speed cams? Shocked
To be fair (though why I should be fair to TT I don't know), cameras do change and extra cams are added and even some removed, but low bridges tend to be fairly static. Very Happy
PostPosted: Sat Nov 29, 2008 10:38 am    Post subject: Reply with quote
norm2002 wrote:
/Ulf
You're right. I dont think that there would be many in the 'mobile' category Shocked
uffe73
PostPosted: Sat Nov 29, 2008 11:04 am    Post subject: Reply with quote
Edit: I didn't see norm2002's answer earlier, which was pretty much identical to mine. Smile
/Ulf
Just like that. Smile....with the only difference that bridges tend to be slightly more permanent than speed cameras... Very Happy
PostPosted: Sat Nov 29, 2008 1:41 pm    Post subject: Reply with quote
uffe73 wrote:
Andy_P wrote:
Laughing Laughing Laughing Laughing
If only it WERE that simple, don't you think all the satnav makers would have done it by now?
Sure it's easy to add the checkboxes, but what do they *do*? Very Happy
Most of the data needed for implementing these extra features should already be included in the maps via the road categories so I don't see the problem. Ok, avoiding low bridges requires a POI list of bridges, but I'm sure TomTom could collect that information easily.
/Ulf
Yes, but my point was that you said "ALL it required was adding a few checkboxes". No it doesn't.
It would need a complete rewrite of the core navigation software to introduce an "Avoid POI" function.
And even then, for all your suggestions except the low bridges, it is not simply avoiding a POI which is a single point on the map, it involves avoiding a whole area. This is already done with the congestion charge area, so it's perfectly possible to do it, and I completely agree that it would be a fantastic addition, but it isn't just adding a few boxes, otherwise they would have done it long ago..
uffe73
PostPosted: Sat Nov 29, 2008 4:31 pm    Post subject: Reply with quote
You're right of courrse. Adding a few check boxes isn't enough for implementi these features. It takes some code behind the buttons.
I'm not an expert of routing algoritms, but I don't see the big difference between implementing Avoid motorways from implementing Plan HGV route, provided that the map contains the data for checking the criteria. Isn't it all about applying a filter when calculating the route? But, then again, I don't know the details of TomTom's routing algoritms so I may be oversimplifying things. Smile
I believe the main question here is if the current maps contain enough information for evaluating the criterias needed for implementing the features I was suggesting. It seems that the TomTom's products are mainly fousing on customers driving private cars, rather than professional drivers, and therefore only includes the map details needed for fulfilling their needs.
Anyway, I have received an answer to my original question, so this is a bit off topic. Smile
PostPosted: Sat Nov 29, 2008 11:30 pm    Post subject: Reply with quote
I believe that TeleAtlas and Navteq have a LOT more miscellaneous data in their mapping than most satnav makers use, manufacturers such as tomTom only buy the "layers" that they need, so it would be an extra cost to them to add things like height and weight restrictions (how much extra, I have NO idea!)
Having said that, TomTom now own TeleAtlas, of course.....
AlandEi
PostPosted: Sun Nov 30, 2008 6:34 pm    Post subject: Reply with quote
Low bridge, dangerous bends ect. POIs are readily available to purchase online, but as my vehicle is below 10' tall, they are not so much of a worry... it is the narrow roads/lanes facility that would be most useful... and it is no use just trying to avoid "B" class roads, as some of those are actually wider than some of the narrower "A" class roads in various parts of the UK...
I have only seen narrow roads POIs advertised as part of a package on one HGV site, and I read on this forum a few weeks ago, that this particular companies package, was not value for money.
I believe that the sort of vehicle recognition I would like to see on the Go devices, is available on, for example the Pronav device by Navevo, which is having very mixed reviews in our HGV/Motorhome Lounge... however, it proves that it is possible, even with current mapping.
Ah ! well... thank goodness for itinerary planning.
Alan.
Tom Tom Go 520 - Map UK ROI 720.1803 Navcore_8.204.9718.go40 - ( Loquendo TTS7 ) / RDS-TMC /Tyre... purchased the Go mainly for the itinerary feature
PostPosted: Mon Dec 01, 2008 9:05 am    Post subject: Reply with quote
as AlandEi states, a sat nav is not an excuse for poor planning!! there is no need for hgv drivers to go down small country lanes after blindly following a sat nav...
Page 2 of 2
22.062 (12 Jun 24)
