Pocket GPS World :: View topic - Got a little problem with my GPS
goryiri
PostPosted: Tue Nov 25, 2008 10:32 am    Post subject: Got a little problem with my GPS Reply with quote
My problem is that I can not access my memory card...This happened while I was trying to install POIwarner(I have installed the application an then when I clicked on navigation on the device it told me that there was no memory card inserted,and obviously the card was in).I have restarted the device and connected it to my pc.I tried to browse the device and the StorageCard folder was not present.I did everything i know and nothing worked(factory reset, removed all)and still doesn't work! I think that if I reinstall the Windows core it will work....but I have no idea of how to do that, so please help me!!!!
My device is Medion Gopal E4430
goryiri
PostPosted: Tue Nov 25, 2008 6:37 pm    Post subject: Reply with quote
PLEASE SOMEBODY HELP MEEEEEE!!!!!!!!!
PostPosted: Tue Nov 25, 2008 7:24 pm    Post subject: Reply with quote
Can you view the card contents using a card reader? Do you have a backup of the files that were on the card?
Pocketgps
PostPosted: Tue Nov 25, 2008 8:56 pm    Post subject: Reply with quote
If you transferred the data to the card via your pc then for some reason the PDA or what ever does not see the data when it should.
I have found the only solution is to transfer the data to the card via active sync, yes very slow I know, but it works.
If you did use your pc, then put the card back in the pc, delete all the files, and then put it back into the PDA or what ever and do it that way.
Do Backup The Card First On Your PC Via Explore Laughing
goryiri
PostPosted: Tue Nov 25, 2008 10:35 pm    Post subject: Reply with quote
The problem is that i don't have a card reader...i used to transfer data via active sync....and i don't need the data on the card anymore...any other solution, cos' i don't have any devices that work with sd cards...if the only solution is to buy a card reader or to try to put the card into another device and see what happens, this will most likely be the last one...so till then do you happen to have any other idea???
aj2052
PostPosted: Wed Nov 26, 2008 2:30 am    Post subject: Reply with quote
You can read a card thru activesync using explore within activesync,can you do this.
Moto G5s Plus, Sygic 17.4.8
goryiri
PostPosted: Thu Nov 27, 2008 2:18 pm    Post subject: Reply with quote
Never mind, i've just bought myself a cardreader an solved the problem...thanks for trying to help, i appreciate it!
PsychoJock
PostPosted: Mon Dec 08, 2008 9:36 pm    Post subject: Reply with quote
Hi All,
One tip on this subject. I find I have to reset my GoPal 210T to make it recognise the card or change of card.
Switching it off and on doesn't do the trick.
Very Happy
Gary
Medion PNA210T,GoPal Navigator 3(ME),POIWarner 2
Samsung S8000 Jet, Looking for Navigation App?
22.105 (30 Oct 24)
