mrfreeze Lifetime Member
Posted: Sat Nov 15, 2008 2:14 pm Post subject: What are the differences between a x20 & x30 |
There was a lot of talk about once you downloaded the v8 maps to a x20 that you would have in reality a x30 device.
While it does give you the features of ALG etc, what i'm asking is what are the physical differences as well as software differences.
The reason this has come up, in the post regarding voice problems since the v8.300 update, it has transpired that the loquendo TTS file is a different version, ie 6.9 as opposed to 7.0
So are the units, say 720 & 730 the same mechanical build up and only different in the software they use or are there physical differences. _________________ Go 720 v8.351 GPS v1.20 Boot 5.5120
Kate v710 UK & ROI v850.2781
Go 920 v8.351 GPS v1.20 Boot 5.5120
Kate v710 UK & ROI v850.2781 |
dhn Frequent Visitor
Posted: Sat Nov 15, 2008 2:38 pm Post subject: |
No physical differences. That's my understanding. _________________ David |
Darren Frequent Visitor
Posted: Sat Nov 15, 2008 3:19 pm Post subject: Re: What are the differences between a x20 & x30 |
mrfreeze wrote: | So are the units, say 720 & 730 the same mechanical build up and only different in the software they use or are there physical differences. |
Exactly. An x20 with v8 software and a v8.10 or later map is identical to an x30 with the same software. _________________ Darren Griffin |
Posted: Sun Nov 16, 2008 12:27 am Post subject: Re: What are the differences between a x20 & x30 |
Darren wrote: | mrfreeze wrote: | So are the units, say 720 & 730 the same mechanical build up and only different in the software they use or are there physical differences. |
Exactly. An x20 with v8 software and a v8.10 or later map is identical to an x30 with the same software. |
No thats just my point, the're not identical.
This whole voice problem has highlighted that the x30 have a newer version loquendo TTs file. So i'm saying what else is different?
I like others have assumed that when you put v8 maps on a x20 it becomes a x30. _________________ Go 720 v8.351 GPS v1.20 Boot 5.5120
Posted: Sun Nov 16, 2008 12:37 am Post subject: |
Other than the colour of the menu screens and background they are identical, you cannot change the menu colour or the device ident as this is set when the device was newly built.
All the other differences are software related, boot screen graphics, LoquendoTTS version are about the only differences I know of between my x20 and x30 units in software terms - Mike |
Posted: Sun Nov 16, 2008 9:55 am Post subject: |
And all these are so minor as to be unimportant. The use, operation and features are identical. The difference between file versions you mention is irrelevant. _________________ Darren Griffin |
Posted: Mon Nov 17, 2008 2:35 am Post subject: |
Without wishing to labour the point, it is relevant.
Not one x30 has reported the voice stuttering that the x20's have been having.
The TTS v7 file seems like it may be a fix for this, so again it does seem relevant.
All i was trying to do was ascertain if that was the only difference. _________________ Go 720 v8.351 GPS v1.20 Boot 5.5120
Posted: Mon Nov 17, 2008 9:26 am Post subject: |
mrfreeze wrote: | Not one x30 has reported the voice stuttering that the x20's have been having. | There ahs been more than one report of stammering x30 devices, but they do seem less affected by this issue. As we said earlier in this thread only difference is really the software, the LoqTTS files being just one small part - Mike |
Posted: Mon Nov 17, 2008 9:34 am Post subject: |
mrfreeze wrote: | Without wishing to labour the point, it is relevant.
All i was trying to do was ascertain if that was the only difference. |
OK I can concede that point! But there was no issue prior to the v8.3 update so the cause lies within that and not necessarily within the TTS files themselves.
TomTom have been notified and we can but hope that a fix will be forthcoming at some point! _________________ Darren Griffin |
dsouter Occasional Visitor
Posted: Mon Nov 17, 2008 8:22 pm Post subject: |
The biggest difference in my experience is that the x30 works. x20s were pathetic.
Duncan _________________ never mind eh!!!
go 1005 |
Posted: Mon Nov 17, 2008 8:25 pm Post subject: |
I must be lucky then, my 520 and 720 both perform perfectly. I don't use FM tx nor do I need an mp3 player but as Nav units they've both been very reliable. _________________ Darren Griffin |
Posted: Mon Nov 17, 2008 9:03 pm Post subject: |
I returned 3 or 4 faulty 720 units (each had different faults), I then bought a 920 which needed two major repairs in 7 months, including replacing the PCB after which it still had many problems. Tom tom finally replaced the 920 with a 930 which is so far absolutely fantastic.
Duncan (AKA Mr lucky) _________________ never mind eh!!!
go 1005 |
AlandEi Regular Visitor
Joined: Aug 18, 2008 Posts: 82 Location: North Wales UK
Posted: Mon Nov 17, 2008 10:08 pm Post subject: |
Quote: | The biggest difference in my experience is that the x30 works. x20s were pathetic | .
Not so Duncan... my Go 520 is a fantastic piece of kit... when loaded with the features that were available when it was released onto the market... It is just that Tom Tom for unknown reasons, have decided to offer X20 owners the same features as X30 devices, which has caused the appearence of two HUGE topics on this forum, due to Tom Tom releasing faulty software updates for the older model... they are in effect identical hardware, and it is due to this hardware, now working close to the limit of it's capacity with this new software on both models, that one small "glitch" in the software will cause it all to go pear shaped...
Alan. _________________ Tom Tom Go 520 - Map UK ROI 720.1803 Navcore_8.204.9718.go40 - ( Loquendo TTS7 ) / RDS-TMC /Tyre... purchased the Go mainly for the itinerary feature |
Posted: Tue Nov 18, 2008 3:54 am Post subject: |
Darren wrote: | I must be lucky then, my 520 and 720 both perform perfectly. I don't use FM tx nor do I need an mp3 player but as Nav units they've both been very reliable. |
I must be unlucky then, as i use mine solely as a GPS, no FM, no MP3, no Traffic, use itenerary and directions!
Thanks for passing on to TT, i hope they get their finger out and sort it. _________________ Go 720 v8.351 GPS v1.20 Boot 5.5120
jonstatt Regular Visitor
Posted: Tue Nov 18, 2008 10:04 am Post subject: |
On a sidenote, the screen quality was better on the 930 than the 920 I had next to it. This may have just been different batches of LCD panels or a deliberate design change. It was easy to see because when switched off, the LCD panels are not the same shade of grey. |
