playswell Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_013.gif)
Posted: Sun Nov 16, 2008 12:15 pm Post subject: 940 memory card |
Is it the Micro sd card the 940 takes? and is it up to 8gb can be used after the latest update? |
Posted: Sun Nov 16, 2008 12:17 pm Post subject: |
Indeed it is the Micro SD type the device uses, as for capacity, anything upto 32GB should work - I use a spare 6GB in my 940 for music - Mike |
Posted: Sun Nov 16, 2008 12:20 pm Post subject: |
mikealder wrote: | Indeed it is the Micro SD type the device uses, as for capacity, anything upto 32GB should work - I use a spare 6GB in my 940 for music - Mike |
Thanks Mike, can it use the extra memory for the operating system as well? |
MrT Frequent Visitor
![](modules/Forums/images/avatars/gallery/065.gif)
Posted: Sun Nov 16, 2008 12:23 pm Post subject: |
I am using a Micro SDHC 8GB.
Here is the list from TomTom:
Memory List |
Posted: Sun Nov 16, 2008 12:29 pm Post subject: |
playswell wrote: | Thanks Mike, can it use the extra memory for the operating system as well? | No it uses the card for storage of whatever you want to put on it, TBH to free up space on my unit I did the full backup and removed the North American map folder from the device. This frees up nearly 2GB and you can always put the map back on the device if you head out in that direction - Mike |
Posted: Sun Nov 16, 2008 2:14 pm Post subject: |
As above I have found that you can put what you want on the card. I copied the full backup to the card when I was trying to resolve issues and found that the unit boots from the card in preference to the internal memory.
I also discovered if you use a different version of the operating system between the card and the internal memory, it wipes out the bluetooth settings. If you use the same version the only issue is that wants you to agree the startup disclaimer again.
If you just move a map folder to the card the unit still sees it.
When you connect to Home it asks if you want to use the system on the card or the internal memory.
If you put the card with the full system in a card reader, Home thinks it has connected to your device and even sees the device number and the device serial number. |
Posted: Tue Nov 18, 2008 8:46 pm Post subject: |
MrT wrote: | As above I have found that you can put what you want on the card. I copied the full backup to the card when I was trying to resolve issues and found that the unit boots from the card in preference to the internal memory.
Thanks for that, I have the fastest 8gb card on the market orderd (transfer rate) |
