Pocket GPS World :: View topic - 940 memory card
940 memory card
playswell
PostPosted: Sun Nov 16, 2008 12:15 pm    Post subject: 940 memory card Reply with quote
Is it the Micro sd card the 940 takes? and is it up to 8gb can be used after the latest update?
PostPosted: Sun Nov 16, 2008 12:17 pm    Post subject: Reply with quote
Indeed it is the Micro SD type the device uses, as for capacity, anything upto 32GB should work - I use a spare 6GB in my 940 for music - Mike
playswell
PostPosted: Sun Nov 16, 2008 12:20 pm    Post subject: Reply with quote
Thanks Mike, can it use the extra memory for the operating system as well?
MrT
PostPosted: Sun Nov 16, 2008 12:23 pm    Post subject: Reply with quote
I am using a Micro SDHC 8GB.
Here is the list from TomTom:
Memory List
PostPosted: Sun Nov 16, 2008 12:29 pm    Post subject: Reply with quote
No it uses the card for storage of whatever you want to put on it, TBH to free up space on my unit I did the full backup and removed the North American map folder from the device. This frees up nearly 2GB and you can always put the map back on the device if you head out in that direction - Mike
MrT
PostPosted: Sun Nov 16, 2008 2:14 pm    Post subject: Reply with quote
As above I have found that you can put what you want on the card. I copied the full backup to the card when I was trying to resolve issues and found that the unit boots from the card in preference to the internal memory.
I also discovered if you use a different version of the operating system between the card and the internal memory, it wipes out the bluetooth settings. If you use the same version the only issue is that wants you to agree the startup disclaimer again.
If you just move a map folder to the card the unit still sees it.
When you connect to Home it asks if you want to use the system on the card or the internal memory.
If you put the card with the full system in a card reader, Home thinks it has connected to your device and even sees the device number and the device serial number.
playswell
PostPosted: Tue Nov 18, 2008 8:46 pm    Post subject: Reply with quote
Thanks for that, I have the fastest 8gb card on the market orderd (transfer rate)
22.063 (19 Jun 24)
