p-brain Occasional Visitor
Posted: Sun Jul 27, 2008 5:32 pm Post subject: Odd behaviour, but not a 'freeze' -position stopped updating |
About 30 mins or so into a walk today, the A10 stopped updating the current position (ie the blue dot). The unit hadn't frozen as it was still responding to button presses, changes in screen etc....but it just wasn't updating to the current position - even after entering planning mode and then trying to return to current position on GPS screen. Had to restart it before it updated to the correct position. First time this has happened to me and I have been using V1.2 for a couple of weeks now.
EDIT: Oops - sorry Mods - I wanted to add this to the V1.20 forum, not start a new topic.... |
4ndynorfolk Regular Visitor
Posted: Sun Jul 27, 2008 6:14 pm Post subject: |
Did you notice what the GPS Status screen said. Sunds very similar to what I described as a freeze in the 1.200 forum.
Mine showed the same symptoms, then froze once I got to the GPS Status screen. |
Posted: Sun Jul 27, 2008 6:21 pm Post subject: |
4ndynorfolk wrote: | Did you notice what the GPS Status screen said. Sunds very similar to what I described as a freeze in the 1.200 forum.
No, I didn't - I will make a note to look next time. All i know is that everything else seemd still to be functioning....unlike other freezes/crashes I have experience where the unit becomes totally inresponsive.
I kept switching between planning and GPS map mode, but it refused to update the current position to the correct position.
I very much doubt it was lack of GPS signal as I was in the middle of a very large flat field with nothing between the A10 and clear sky in all directions! |
PloddinPedro Regular Visitor
Posted: Tue Jul 29, 2008 10:21 pm Post subject: |
I had this happen to me today - very disappointing, especially as the v1.200 seems to be an improvement otherwise. Anyone else out there experiencing this? |
Posted: Wed Jul 30, 2008 12:11 am Post subject: |
Did you guys report this to Satmap? |
Posted: Wed Jul 30, 2008 6:20 am Post subject: |
4ndynorfolk wrote: | Did you guys report this to Satmap? | No, not yet. I was going to continue using the A10 and see if it recurred. |
Posted: Wed Jul 30, 2008 8:46 am Post subject: |
PloddinPedro wrote: | 4ndynorfolk wrote: | Did you guys report this to Satmap? | No, not yet. I was going to continue using the A10 and see if it recurred. |
Is there a particular route one should use to report this to Satmap - or just by email? I am happy to notify them. |
Posted: Wed Jul 30, 2008 11:17 am Post subject: |
Last week, when I tried to talk them through some quite fundemental bugs in the co-ord entry screen##, the person I spoke to, did not seem seem too bothered, and asked me to email to info@satmap.com. It was lunchtime and the phone may not have been answered by by the correct department.
I take the view that if we don't report issues, they they won't get fixed. After all, if we find them, they have already got through Satmap's own (exhaustive?) testing and the beta testing. It would be nice to think that one of Satmap's tech support team monitored and contributed to this forum. If they do, they have yet to identify themselves.
##I have not reported these here as they are obvious bugs in the program, and not abe to be sorted out amongst ourselves. |
robertharvey Occasional Visitor
Posted: Tue Nov 04, 2008 5:53 pm Post subject: |
I have the exact problem, description below
I have had an issue now a number of times whereby the Active 10 stops tracking my current position.
On the GPS screen it shows orange bars and a green satellite image to confirm you have a lock.
However when you move the blue position dot stays fixed to it's last position. The only way to rectify the problem is to power down and up again. After lock is gained again a trail of red dots is shown from the stuck position to the new current position and a correct blue dot is shown.
This has caused me a number of navigation issues, as nothing seems to be wrong at first, until you realise you are not moving on the map.
I had wondered whether this was hardware or software, but I suppose this thread has answered my question. This is a V1.20 issue! Role on V1.21. Let's hope Satmap take a look at the wish list also. |
LostMike Frequent Visitor
Joined: Jan 17, 2008 Posts: 369 Location: Monmouthshire
Posted: Tue Nov 04, 2008 6:25 pm Post subject: |
Satmap advised me to reinstall version 1.2 and reset all defaults. They did not seem to sure why they were recommending this but I did it and so far it seems to have worked. Before I did this I had started to get lock ups on almost every walk. _________________ LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525 |
Afuss Occasional Visitor
Posted: Tue Nov 11, 2008 5:24 pm Post subject: Position Not Updating |
My Satmap froze with blue position dot not updating (still responds to key presses though) today. I'm using version 1.2 firmware with full GB map South section. Never had any problems before using 1:50k Central region and 1:25k Peak District map cards. Perhaps the problem relates to the map size? |
Posted: Tue Nov 11, 2008 7:12 pm Post subject: |
I'm not sure it is map size. I had problems with a 1:25000 map of the Brecon Beacons and separately with a half UK 1:50000 map. The problems also occurred with none and many routes on the A10.
However since doing the reinstall I'm pleased to say that I haven't had any lock ups. _________________ LostMike
Satsync 1.525 |
lightshipman Occasional Visitor
Posted: Fri Nov 14, 2008 9:03 pm Post subject: |
I use Satmap on my mountain bike, I have only had the unit since Monday, I have done about 50 miles of off road routes this week with out the trail snail, however I remembered to switch it on today and it froze on me, I checked the card for free space and there was plenty, I am using Wales 1:50000 mapping, I had to turn it off and on to sort the stationary blue dot problem. apart from this glitch I am very happy with the Satmap. |
Bosun Frequent Visitor
Joined: May 02, 2005 Posts: 473 Location: Wakefield,West Riding of Yorkshire
Posted: Sun Nov 30, 2008 6:57 pm Post subject: |
I have had exactly the same thing on a Garmin 60CS more than once so it is not unique to the SatMap.
With regard to reporting things to SatMap,I think we should report every problem we come across,there is no guarantee that SatMap read this forum and their own isn't up and running yet so if things aren't reported they can hardly be rectified.
Ian |
Darren Frequent Visitor
Posted: Sun Nov 30, 2008 7:41 pm Post subject: |
Bosun wrote: | there is no guarantee that SatMap read this forum |
Rest assured they do. _________________ Darren Griffin |
