Earle Occasional Visitor
Posted: Wed Nov 12, 2008 5:59 pm Post subject: ipaq navigator 6 map orientation |
hi,
just bought nav 6 for my ipaq and on the nav 5 software you could switch the map orientation so i could look at the maps landscape so it sits on the dash better within the gps holder.
Would be grateful if somebody could tell me if there is a way of doing this, i cant believe i have upgraded and there is less function
thanks in anticipation |
Posted: Wed Nov 12, 2008 6:07 pm Post subject: |
The screen rotate function was removed, what you can do is rotate the screen using the PDA screen orientation settings before you launch the nav app, if your PDA is running WM2003SE of later it should have this option within the OS, if it is earlier than 2003SE you would have to look for a third party application to rotate the screen - Mike |
Posted: Wed Nov 12, 2008 7:26 pm Post subject: screen rotation |
Thanks for that...i have looked all around my ipaq and i cannot find the screen rotation menu ....could you give my a steer to where to find it please....still miffed that it is not included so much for progress eh!
Cheers again |
Posted: Wed Nov 12, 2008 7:36 pm Post subject: |
Start/ Settings _ System Tab then choose screen, if orientation is supported you should have an option for Portrait/ Landscape
Which iPAQ model number is it you are using? - Mike |
Posted: Wed Nov 12, 2008 8:12 pm Post subject: |
mikealder wrote: | Start/ Settings _ System Tab then choose screen, if orientation is supported you should have an option for Portrait/ Landscape
ipaq H2200...thinking it doest support it.....you mentioned before a 3rd party app to help ...where would i find that?
cheers again |
