Pocket GPS World :: View topic - text to speach on 540
abercomp
PostPosted: Wed Nov 05, 2008 8:36 pm    Post subject: text to speach on 540 Reply with quote
is there a way you can set an alert on poi that say what you put in the text like on the 720?
PostPosted: Wed Nov 05, 2008 8:58 pm    Post subject: Reply with quote
It works in exactly the same way as the x20/ x30 units in this respect.
Make sure you have a computer voice selected then you can type the POI warning when setting up the Warn When Near POI options - Mike
abercomp
PostPosted: Wed Nov 05, 2008 9:06 pm    Post subject: Reply with quote
hi i have a computer vice selected but i dont get the option for text?
PostPosted: Wed Nov 05, 2008 9:24 pm    Post subject: Re: text to speach on 540 Reply with quote
abercomp wrote:
  1. Manage POIs
  2. Change preferences
  3. Warn when near POI
  4. Choose your POI
  5. Select Warning distance
  6. Choose 'Type in your own warning'
Just tried it on my 940 and it works?
abercomp
PostPosted: Wed Nov 05, 2008 10:21 pm    Post subject: Re: text to speach on 540 Reply with quote
abercomp wrote:
  1. Manage POIs
  4. Choose your POI
ahh right thanks i was trying to change it where they defoult bells etc are for schools ect
is it possible to get speach on safety camers also on the 540 i can only seam to pick the standard bells etc?
thansks
abercomp
PostPosted: Sat Nov 08, 2008 8:04 pm    Post subject: Re: text to speach on 540 Reply with quote
abercomp wrote:
abercomp wrote:
  1. Manage POIs
  4. Choose your POI
thansks
thanks
PostPosted: Sat Nov 08, 2008 8:06 pm    Post subject: Reply with quote
Is this using the Speed Camera database from PocketGPSWorld or using the Safety Cameras supplied with the device? - Mike
abercomp
PostPosted: Sat Nov 08, 2008 8:39 pm    Post subject: Reply with quote
hi supplied on the device i could get speach on the 720
PostPosted: Sat Nov 08, 2008 9:04 pm    Post subject: Reply with quote
You cannot use the Text To Speech for the built in TomTom supplied database, what you can do is either record your own warning or save a warning you want to use as a wav file and put it in the Sounds folder on the device. Once the file is in the Sounds folder it can be selected when you configure the warnings for the built in cameras.
This provides far less options than with the normal POI files which as you know can use the TTS system of ogg audio files - Mike
mikero
PostPosted: Sun Nov 09, 2008 10:00 am    Post subject: Reply with quote
abercomp wrote:
I used the services of a free "Text to Speech" website. I entered the text for each of the Tomtom safety cameras, e.g. "Fixed Safety Camera, Ungated Railway Crossing", then saved the .wav files. These files were then transferred to the Sounds folder on my device and linked to the individual cameras using the "Change Warning Preferences" tab within TomTom Safety Cameras.
One point to remember when using these sites (most are American) is that the word "MOBILE" is pronounced "MOBEEL" so I changed the spelling to "MOBYLE" to achieve the desired result.
Once on my device, I found that the warnings were not as loud as the ones generated by the PGPSW files so I used Nero Wave Editor to increase the volume and now they work a treat!
PostPosted: Sun Nov 09, 2008 10:04 am    Post subject: Reply with quote
Another way is to use the device itself to play the spoken alert whilst sending the audio out through the line out socket straight into the PC's sound card. This way you get the spoken alerts in the same voice that the device uses for navigation - messy though to produce a full set, but it can be done - Mike
abercomp
PostPosted: Sun Nov 09, 2008 10:47 am    Post subject: Reply with quote
mikero wrote:
abercomp wrote:
thanks could you send me a copy of the files or point me to the website thanks
mikero
PostPosted: Sun Nov 09, 2008 10:56 am    Post subject: Reply with quote
abercomp wrote:
mikero wrote:
abercomp wrote:
I have sent you a PM with the website address.
MrT
PostPosted: Sun Nov 09, 2008 11:08 am    Post subject: Reply with quote
I use the pocketgpsworld cameras but I rename the files to names such as "20 mph gatso.ov2" and select brief announcement in the POI warning options and the unit will then say on approaching a camera "20 miles per hour gatso 200 yards" using its text to voice (yes it reads out mph as miles per hour). If you use long announcement it also tells you the distance to the next nearest similar camera that may not be on your route.
As there are 60 PocketGPS files to rename, I wrote a simple batch file to run everytime there is an update.
Another point is that if you try to set up POI warnings when the unit is connected to Home on the PC, the voice options are not shown.
abercomp
PostPosted: Sun Nov 09, 2008 11:14 am    Post subject: Reply with quote
mikero wrote:
abercomp wrote:
mikero wrote:
abercomp wrote:
thanks
