Pocket GPS World :: View topic - Fix 940 to Proclip?
Fix 940 to Proclip?
nashmills
PostPosted: Thu Nov 06, 2008 9:24 pm    Post subject: Fix 940 to Proclip? Reply with quote
I can't get on with the sticky active mount that came with my 940. Has anybody found something suitable that will fix to a Brodit Proclip yet please?
PostPosted: Thu Nov 06, 2008 9:48 pm    Post subject: Reply with quote
Bit early for custom solutions as yet. You could use one of the adhesive discs, stick that to the ProClip and then use the x40 mount to affix to that.
nashmills
PostPosted: Thu Nov 06, 2008 9:54 pm    Post subject: Reply with quote
Thanks for the suggestion. I was thinking along those lines but my proclip is not at a suitable angle for the active mount and the mount won't swivel in the right direction.
PostPosted: Thu Nov 06, 2008 9:57 pm    Post subject: Reply with quote
I know Carcomm are working on a cradle which I'm eagerly awaiting. Brodit will doubtless have one on the drawing board too.
In the meantime, how about using the disc attached to the dashboard?
nashmills
PostPosted: Thu Nov 06, 2008 10:01 pm    Post subject: Reply with quote
I would assume you would need a flat, vertical surface to use the discs on the dash? Sadly I have nothing like that in my car.
PostPosted: Thu Nov 06, 2008 10:29 pm    Post subject: Reply with quote
Flat yes but doesn't need to be vertical, what car do you have??
nashmills
PostPosted: Thu Nov 06, 2008 10:36 pm    Post subject: Reply with quote
Toyota Aygo
PostPosted: Thu Nov 06, 2008 10:41 pm    Post subject: Reply with quote
I'd have thought there was enough room on the dash top between speedo cluster and centre console for a disc?
nashmills
PostPosted: Thu Nov 06, 2008 10:47 pm    Post subject: Reply with quote
Plenty but I can't seem to get the active mount to twist to the right angle which would enable horizontal mounting.
nashmills
PostPosted: Thu Nov 06, 2008 10:49 pm    Post subject: Reply with quote
Sorted it. You're a star. Thank you.
PostPosted: Thu Nov 06, 2008 10:51 pm    Post subject: Reply with quote
? I have my 940 on the dashtop of my car affixed to a disc mounted horizontally? It works fine in that orientation. The actual dock can be rotated 360º With the 'foot' in the horizontal plane and the arm curving towards you rotate the dock until it is orientated with sync port facing up?
PostPosted: Thu Nov 06, 2008 10:52 pm    Post subject: Reply with quote
Very Happy Is there enough adjustment for this to fit on your ProClip with a dash disc now then?
nashmills
PostPosted: Thu Nov 06, 2008 11:02 pm    Post subject: Reply with quote
Yes it was just a bit stiff. I have it to the right angle now. I don't suppose you know of any shops that would sell the discs rather than wait for online delivery?
nashmills
PostPosted: Thu Nov 06, 2008 11:34 pm    Post subject: Reply with quote
That would be nice. I have ordered a couple for collection from John Lewis on Saturday. Fingers crossed I will be sorted until a custom mount appears.
PostPosted: Fri Nov 07, 2008 12:46 am    Post subject: Reply with quote
If you want a true custom mount make your own, its not difficult and I am sure the x40 mount would yield in a similar way to what I did with the x20 last year, see Here Unless you need connections for something other than power - Mike
22.064 (26 Jun 24)
