Pocket GPS World :: View topic - speed camera voices not working
hissinsid
PostPosted: Sat Oct 25, 2008 7:14 pm    Post subject: speed camera voices not working Reply with quote
hi i downloaded the speed camera voices to a folder then added the speed cameras and uploaded the to my nuvi 660 but the voices dont work when i downloaded the voices and opened the folder they were windows media files mp3 how do i convert them to ogg files am i missing something somewhere.
regards.
gus.
PaulB2005
PostPosted: Sat Oct 25, 2008 7:51 pm    Post subject: Reply with quote
For the Garmins they need to be mp3 - hence the Garmin downloads are mp3 and not ogg.
Then you need to add them to the folder you keep your POIs in and then upload the lot with POILoader. Make sure you have mp3 that match the names of your CSV files.
hissinsid
PostPosted: Sat Oct 25, 2008 8:25 pm    Post subject: Reply with quote
hi paul what do you mean match the files.
Oldboy
PostPosted: Sat Oct 25, 2008 9:01 pm    Post subject: Reply with quote
He means that the Filename has to be the same in both cases.
As in Gatso.csv and Gatso.mp3
PaulB2005
Well say you already have
GATSO.CSV
and
from the database, you need the mp3 you to sound when you go near a GATSO to be called GATSO.mp3...
hissinsid
PostPosted: Sun Oct 26, 2008 2:26 pm    Post subject: Reply with quote
hi guys i have all the files as you say gatso csv bmp and gatso mp3 in all the speeds and all the other cameras and mp3s to go along with them but still not working do i have to disable the prloaded ones first in order for the pocket ones to work they are on a sd card.
regards.
gus.
PaulB2005
PostPosted: Sun Oct 26, 2008 3:17 pm    Post subject: Reply with quote
You don't need to disable the built in ones first - although it might be an idea. The last person to have this trouble found he didn't have enough room on his card and it was only after he freed up some space that it worked.
It looks like you are using the Speed Zoned Database which will result in a large number of mp3 needing to be transferred and will create a huge POI.GPI file. This maybe the problem.
Try the following:
1) When given the option by POILoader of where to save the files save it to your PC (Custom Folder) and not the Nuvi or the SD card. How big is the file it creates?
2) Will this fit into your SD card or the Nuvi memory?
3) Try the Consolidated database or the Single File. These use less files and less mp3s.
