hi8prt Occasional Visitor
Posted: Mon Oct 20, 2008 12:55 am Post subject: sticking bluetooth or speaker |
hi, iam having a problem with my ttgo 720. when using my phone (sony erricson 810i) my tomtom freezes , that is the internal speakerand no matter what you do it continues until after about 60 or so second it turns its self off then on again and rests its self ie no route planned plus all other settings return to factory settings. any ideas cheers Phil |
AndyVaughan Lifetime Member
Joined: Apr 13, 2006 Posts: 1500 Location: Rossendale
Posted: Mon Oct 20, 2008 7:03 pm Post subject: |
Well known bug on x20s and x30s - the only cure is not use the TT as a handsfree unit.
There is a possibility that it corrupts some files when it hangs as well - gnsdata and mapsettings.cfg are the usual suspects.
Some have managed to get it to go away (for a while) by using the clearflash tool and doing a hard reset.
Andy |
Posted: Mon Oct 20, 2008 8:31 pm Post subject: |
hi AndyVaughan , thanks for your reply was not aware of the problem unfortunatley this was a major factor in purchasing the 720. iam concerned about you saying about possible corruption(A) will this affect my sat nav (B) in what way (C)can i check to see if it is (D)can it be repaired/cleaned and if so how. cheers Phil. |
mattstachurski Lifetime Member
DennisN Tired Old Man
Posted: Mon Oct 20, 2008 9:55 pm Post subject: |
Are you using Traffic?
Have you got a gnsdata file? If so, try deleting it. This does NO HARM at all as the TT will create a new one at boot up.
If you can't delete the gnsdata file completely, that's confirmation it is corrupted.
This thread is one of several (it's just a bit shorter than most) in which you can find the way to get rid of corrupt gnsdata file. _________________ Dennis
Two of them are obesiting!! |
Posted: Tue Oct 21, 2008 11:51 pm Post subject: |
hi DennisN, no iam not using traffic. just finished work will check TT out tomrrow as iam b-----d right now will keep you informed cheers Phil |
