Pocket GPS World :: View topic - poi editor message
poi editor message
andybir
PostPosted: Sat Oct 18, 2008 12:49 pm    Post subject: poi editor message Reply with quote
message from a newbie,
when trying to upload speed camera file using the instrutions and download all goes well everything looks the same as per instruction until i press save to device ,ok for 30 sec then i get message from poi editor 'names and places exceeded 16MB limit ok'
any ideas on what to do next many thanks andy .
sorry if this in the wrong section
PostPosted: Sat Oct 18, 2008 12:53 pm    Post subject: Reply with quote
Welcome to the forum Andy, when you say speed cameras are they the files from this site? and also what hardware/ software are you trying to use the files with? - Mike
andybir
PostPosted: Sat Oct 18, 2008 1:04 pm    Post subject: speed Reply with quote
yes i beleive from this site it was about 2am wheniwas`trying it reads 'gasto.uk.csv 169KB' ANd using the smart sd software thanks
PostPosted: Sat Oct 18, 2008 1:25 pm    Post subject: Reply with quote
This site doesn't support the use of POI Edit for any of the POI downloads, you need to be a site member, logged in and download the required file type using your Internet Browser, the download is then unzipped to produce the actual POI files which can be copied to the device.
Can you be more specfic as to the software you intend using the speed camera files with as I have not heard of "smart sd software" before? - Mike
andybir
PostPosted: Sat Oct 18, 2008 3:49 pm    Post subject: Reply with quote
//Navman_SmartST_v3.0_Application_Installer_For_ICN_510_this is software and i have navman icn 510
PostPosted: Sun Oct 19, 2008 10:07 pm    Post subject: Reply with quote
The instructions to download and install the camera database to various devices are HERE where there is a large green and yellow table showing every model and with clickable links to the specific instructions for that model.
Unfortunately, it would appear that the Navman iCN v2 is one of the few models that cannot use the database, but so long as you have the v3, you should be fine.
So once you have subscribed to the members area of the site, just download the ".asc" file format version and follow the instructions HERE (especially the note in red halfway down!)
navver
PostPosted: Fri Oct 24, 2008 10:10 pm    Post subject: Reply with quote
I had a Navman 635 and used the PGPSW speed cameras before they started charging.
I had trouble with the files.
If I LOADED & SAVED WITH Excel they wouldn't load into Navman. You must open them with Notepad only.
Also I had to search & replace the @ symbol with AT
I did Email PGPSW at the time but they didn't change the database format
Hope this helps.
