Pocket GPS World :: View topic - TomTom TMC/iPod extension cable for 910
DeLorean
PostPosted: Fri Oct 17, 2008 4:48 pm    Post subject: TomTom TMC/iPod extension cable for 910 Reply with quote
Hi Very Happy
Does anyone know where you can get a 4 pole 2.5mm extention cable suitable for extending the iPod/TMC cable on a TomTom GO 910 Question
Ta very much Very Happy
🔸🔸 Currently using TomTom GO 940 & Locus Map 🔸🔸
PostPosted: Fri Oct 17, 2008 5:01 pm    Post subject: Reply with quote
It is actually a 6 pole connector, take a closer look at the inside edges of the connector body and you will see two additional copper rings, these are also used for either power or data I cannot remember which to be honest! But I do have the pinout diagram Idrew on the PC somewhere if that is of use.
These connectors are obviously available as some of the third party mount suppliers have been fiting them to their products, but I have yet to see them on sale as individual leads - Mike
DeLorean
PostPosted: Fri Oct 17, 2008 5:19 pm    Post subject: Reply with quote
Thanks Mike Very Happy
You’re quite right; after popping on my glasses I can see a double ringed collar around the 2.5mm jack.
A pin-out of the connector would be really useful Very Happy
I've got a spare TomTom iPod cable I can cannibalise for the male end; I’ll just need to find the illusive female end Confused
PostPosted: Fri Oct 17, 2008 7:03 pm    Post subject: Reply with quote
The RDS-TMC only uses four wires rather than the six connections available, I have no idea if the iPOD cables uses all six or possibly a different four out of the six available, so you could end up scrapping the cable in way of experimentation.
For a socket I would try posting in the for sale/ wanted section of the forum and ask for an x10 droopy mount, there are probably quite a few knocking about in peoples spares boxes, you can simply take it apart and unsolder the connector from the PCB in the scrap mount - Mike
Calomax
PostPosted: Fri Oct 17, 2008 10:15 pm    Post subject: Reply with quote
Could you not just purchase a longer cable on eBay or somewhere? I bought a 1 metre one to connect my TT to the car stereo. Surely that would also work with an iPod. I haven't tried because I have a short cable to connect the iPod to the stereo but my iPod ear pieces work fine when plugged into the TomTom.
TT Go Essential
PostPosted: Fri Oct 17, 2008 10:56 pm    Post subject: Reply with quote
But this is to extend the RDS TMC receiver cable which is slightly more complicated due to the odd ball connectors TomTom have decided to use, if anyone knows of an extension cable for the RDS or ipod units I would be very interested as it would reduce all the wires I have strewn about in the car - Mike
DeLorean
PostPosted: Fri Oct 17, 2008 11:04 pm    Post subject: Reply with quote
I’ve scoured the web and eBay for a cable, but to no avail Sad
DeLorean
PostPosted: Tue Nov 18, 2008 2:57 pm    Post subject: Reply with quote
OK, I've bought a faulty docking shoe and TMC receiver off fleabay Very Happy
It turns out that the cable on the TMC receiver had as few broken wires where the wire leave the plug.
I’ve successfully peeled the rubber outer off the plug (in one piece!) and trimmed all the epoxy off the back of the plug Very Happy
Why did TomTom use such a ridiculous connector Exclamation
There are 6 outputs on the back of the connector so it’s going to be fiddly to solder Shocked
Fortunately the TMC antenna only requires 4 of these 6 outputs.
Let's see if I can make my extension cable or I end up killing my Go 910 Exclamation
It's a bit like Blue Peter Very Happy
22.064 (26 Jun 24)
