steve99uk Occasional Visitor
Posted: Fri Jun 13, 2008 1:52 pm Post subject: Problem loading to a Kenwood DNX8220BT |
I am trying to load the latest camera DB to a DNX8220BT. I can download it, unzip and load via POI Loader to an SD card. The Kenwood reads the card and says that internal memory will be updated. I select 'yes' and it tells me that the update was successfully completed. However there are no Custom POI loaded to the unit! I have tried different CSV files via POILoader and two different SD cards. Nothing ever shows up in the unit but it always tells me that the load is successful.
The two SD cards I used were a 1GB Sandisk Ultra and a 32MB Sandisk mini-SD with an adaptor.
The file on the card was in directory Garmin\POI\POI.GPI
I have seen another post re a Kenwood DNX7200 where they had a similar problem that was fixed with a different SD card but I have tried two cards - admittedly both Sandisk.
Garmin don't know why and Kenwood tech support are not sure either.
Does anyone have any ideas ?
TIA
Steve |
oakduc999 Occasional Visitor
Posted: Fri Sep 12, 2008 7:00 am Post subject: Problem Uploading Custom POIs to Kenwood DNX8220BT |
I recently figured this one out. I wanted to see all ESSO and Aral gas stations in Germany and needed to see the icons at big map scale so I could plan trips accordingly.
Bottom line: SET CUSTOM POI SCALE TO 8km (or some map scale in that neighborhood)
Go to the map menu in tools. There is a submenu where you can set the map scale at which custom POIs will appear. By default, I guess, the scale for custom POIs is something like 800m which means you won't see them unless the map view is zoomed to that very tight scale and you happen to be right on top of one of your custom POIs.
Everything was happening as described by steve99uk. I used POI loader, saved files to a 2gig sandisk sd card, system read the card and announced that the custom POIs were uploaded. However, when looking at the "Custom POI" screen, it doesn't display anything. The POIs are in fact there, you just can't see a list of them. (which is what I expected) When I went to the map view, I couldn't see my POIs. |
dema Occasional Visitor
Posted: Sun Oct 12, 2008 6:04 pm Post subject: |
hi people
i would like to updated POI on my kenwood dnx 7220 , using poi loader, but question , where is SD CARD reader on 7220-
do i have to use UBS AND then connect card reader with poiloader on it.??
thanks for help
byez
dema |
Darren Frequent Visitor
Posted: Sun Oct 12, 2008 6:17 pm Post subject: |
IIRC you need to burn the files to a CD. _________________ Darren Griffin |
Posted: Tue Oct 14, 2008 11:21 am Post subject: |
Darren wrote: | IIRC you need to burn the files to a CD. |
sorry tried to burn cd , but dnx722o says cd error.
would you please help me to find other solution
do i can use usb with pen drive ??
thanks for replay
dema |
Posted: Tue Oct 14, 2008 11:59 am Post subject: |
How did you burn the files to CD? Was it with the Windows built in CD burning software? If so, this will not work. You must use something like Nero or ImgBurn and "Finalise" the disk. |
Posted: Tue Oct 14, 2008 12:39 pm Post subject: |
dema wrote: | sorry tried to burn cd , but dnx722o says cd error.
thanks for replay
dema |
Does the x220 have a USB port or SD card slot? _________________ Darren Griffin |
Posted: Tue Oct 14, 2008 2:10 pm Post subject: |
PaulB2005 wrote: | How did you burn the files to CD? Was it with the Windows built in CD burning software? If so, this will not work. You must use something like Nero or ImgBurn and "Finalise" the disk. |
i burn cd using NERO and I finalized it.
i created the path Garmin\POI saving in it file generate by POILOADER.
thanks for help again.
dema |
Posted: Tue Oct 14, 2008 2:11 pm Post subject: |
Darren wrote: | dema wrote: | sorry tried to burn cd , but dnx722o says cd error.
thanks for replay
dema |
Does the x220 have a USB port or SD card slot? |
USB port , any solution by using this usb port??
thanks
dema |
Posted: Tue Oct 14, 2008 2:14 pm Post subject: |
It might work, try following the install guide but using a memstick instead of an SD card? _________________ Darren Griffin |
Posted: Tue Oct 14, 2008 3:11 pm Post subject: |
Darren wrote: | It might work, try following the install guide but using a memstick instead of an SD card? |
no doesn't work , tried to use pen drive and copy poiloader, but dosen't recognise file, just mp3
dema |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15150 Location: Bradford, West Yorkshire
Posted: Tue Oct 14, 2008 6:59 pm Post subject: |
dema wrote: | and copy poiloader, but dosen't recognise file, just mp3 |
you need to run poiloader on your pc as opposed to on the device. poiloader will then create the files on the memory stick (you will need to select it as the target) - the device should then detect the files?
MaFt |
Posted: Tue Oct 14, 2008 11:05 pm Post subject: |
thanks to all of you
found solution changed 3 sd cards 1mb, 2 mb 4 mb, last one working fine.
upload successfull.
thanks again
dema
ps next time i will try use pen drive again .never knows |
Posted: Wed Oct 15, 2008 7:49 am Post subject: |
Excellent, if you do success with a memstick let us know? _________________ Darren Griffin |
