Pocket GPS World :: View topic - Problem loading to a Kenwood DNX8220BT
steve99uk
PostPosted: Fri Jun 13, 2008 1:52 pm    Post subject: Problem loading to a Kenwood DNX8220BT Reply with quote
I am trying to load the latest camera DB to a DNX8220BT. I can download it, unzip and load via POI Loader to an SD card. The Kenwood reads the card and says that internal memory will be updated. I select 'yes' and it tells me that the update was successfully completed. However there are no Custom POI loaded to the unit! I have tried different CSV files via POILoader and two different SD cards. Nothing ever shows up in the unit but it always tells me that the load is successful.
The two SD cards I used were a 1GB Sandisk Ultra and a 32MB Sandisk mini-SD with an adaptor.
The file on the card was in directory Garmin\POI\POI.GPI
I have seen another post re a Kenwood DNX7200 where they had a similar problem that was fixed with a different SD card but I have tried two cards - admittedly both Sandisk.
Garmin don't know why and Kenwood tech support are not sure either.
Does anyone have any ideas ? Sad
TIA
Steve
oakduc999
PostPosted: Fri Sep 12, 2008 7:00 am    Post subject: Problem Uploading Custom POIs to Kenwood DNX8220BT Reply with quote
I recently figured this one out. I wanted to see all ESSO and Aral gas stations in Germany and needed to see the icons at big map scale so I could plan trips accordingly.
Bottom line: SET CUSTOM POI SCALE TO 8km (or some map scale in that neighborhood)
Go to the map menu in tools. There is a submenu where you can set the map scale at which custom POIs will appear. By default, I guess, the scale for custom POIs is something like 800m which means you won't see them unless the map view is zoomed to that very tight scale and you happen to be right on top of one of your custom POIs.
Everything was happening as described by steve99uk. I used POI loader, saved files to a 2gig sandisk sd card, system read the card and announced that the custom POIs were uploaded. However, when looking at the "Custom POI" screen, it doesn't display anything. The POIs are in fact there, you just can't see a list of them. (which is what I expected) When I went to the map view, I couldn't see my POIs.
dema
PostPosted: Sun Oct 12, 2008 6:04 pm    Post subject: Reply with quote
hi people
i would like to updated POI on my kenwood dnx 7220 , using poi loader, but question , where is SD CARD reader on 7220-
do i have to use UBS AND then connect card reader with poiloader on it.??
thanks for help
byez
dema Cool
PostPosted: Sun Oct 12, 2008 6:17 pm    Post subject: Reply with quote
IIRC you need to burn the files to a CD.
dema
PostPosted: Tue Oct 14, 2008 11:21 am    Post subject: Reply with quote
sorry tried to burn cd , but dnx722o says cd error.
would you please help me to find other solution
do i can use usb with pen drive ??
thanks for replay
dema Cool
PaulB2005
PostPosted: Tue Oct 14, 2008 11:59 am    Post subject: Reply with quote
How did you burn the files to CD? Was it with the Windows built in CD burning software? If so, this will not work. You must use something like Nero or ImgBurn and "Finalise" the disk.
PostPosted: Tue Oct 14, 2008 12:39 pm    Post subject: Reply with quote
thanks for replay
dema Cool
Does the x220 have a USB port or SD card slot?
dema
PostPosted: Tue Oct 14, 2008 2:10 pm    Post subject: Reply with quote
i burn cd using NERO and I finalized it.
i created the path Garmin\POI saving in it file generate by POILOADER.
thanks for help again.
dema Cool
dema
PostPosted: Tue Oct 14, 2008 2:11 pm    Post subject: Reply with quote
thanks for replay
dema Cool
USB port , any solution by using this usb port??
thanks
dema Cool
PostPosted: Tue Oct 14, 2008 2:14 pm    Post subject: Reply with quote
It might work, try following the install guide but using a memstick instead of an SD card?
dema
PostPosted: Tue Oct 14, 2008 3:11 pm    Post subject: Reply with quote
no doesn't work , tried to use pen drive and copy poiloader, but dosen't recognise file, just mp3
dema Cool
PostPosted: Tue Oct 14, 2008 6:59 pm    Post subject: Reply with quote
you need to run poiloader on your pc as opposed to on the device. poiloader will then create the files on the memory stick (you will need to select it as the target) - the device should then detect the files?
dema
PostPosted: Tue Oct 14, 2008 11:05 pm    Post subject: Reply with quote
thanks to all of you
found solution changed 3 sd cards 1mb, 2 mb 4 mb, last one working fine.
upload successfull.
thanks again
dema Cool
ps next time i will try use pen drive again .never knows
PostPosted: Wed Oct 15, 2008 7:49 am    Post subject: Reply with quote
Excellent, if you do success with a memstick let us know?
22.055 (29 May 24)
