mark1968 Frequent Visitor
Joined: Mar 01, 2004 Posts: 290 Location: Northampton
Posted: Tue Sep 30, 2008 12:35 pm Post subject: Samsung Omnia |
Has anyone been able to get this software to run onthe Omnia. I am asking this because this PDA has an unusual sized screen _________________ Please follow me on twitter @mdyson1968 |
Posted: Tue Oct 07, 2008 9:24 pm Post subject: |
One of the chaps at work has been messing around with this and got nowhere, last week we also tried McGuider on the Omnia which installed correctly but the phone wouldn't get past the password screen. Removal of the memory card and a reset sorted that issue out.
The strange screen size might take a while for program creators to catch up with these devices, if too many different screen sizes appear to market then they probably won't get much mainstream software - Mike |
dascaio Occasional Visitor
Posted: Thu Oct 09, 2008 9:04 am Post subject: |
I manage to run IGO 8 on my Omnia but only in landscape mode. You have to replace your SYS and Data files buy adapted ones. They are available on a few forums |
mxmaciek Lifetime Member
Joined: Jun 20, 2007 Posts: 117 Location: UK, Nottingham
Posted: Mon Oct 27, 2008 12:55 pm Post subject: |
The simplest way: to find a skin with 242x400 & 400x242 support.
While digging some forums, I've found dimka skin modified especially for Omnia.
Update: I'ce just took look at http://navngo.com/pages/global/eng/news_and_press/samsung_eng_20081008 , where you can see the Omnia with horizontal (startup screen) & vertical (nav screen) modes. |
drbf Occasional Visitor
Posted: Sat Nov 15, 2008 10:37 pm Post subject: Omnia |
Igo8 runs great on the Omnia with the dimka skin that has modified especially for Omnia |
Posted: Sun Nov 16, 2008 10:09 am Post subject: |
Mhm... which modification? Typical Dimka skin contains too many and too small info... |
insect Occasional Visitor
Posted: Mon Dec 22, 2008 8:42 pm Post subject: Just fine |
I use iGO8 on my Omnia. The screen is not a problem you can use it in both ways. Everything is absolutely fine |
Shuttlez Occasional Visitor
Posted: Mon Dec 29, 2008 3:08 am Post subject: |
Same here. I can use it both landscape and portrait with the standard skin. I'm using ver8.0 as the current Australian Sensis R15 map is incompatible with 8.3
Oh well. I'll have to wait until then new R16 map is released in Feb (I hope!) |
lexal13 Occasional Visitor
Posted: Tue Jul 14, 2009 12:59 am Post subject: |
[quote="mxmaciek"]The simplest way: to find a skin with 242x400 & 400x242 support.
the omnia uses 200x400 or 400x200 ,and if you open the contents of the data.zip file, then ui_igo8 youll see the list of resolutions that the skin supports, if you try to run a skin without the resolution the omnia throws up a ferrui error
Posted: Tue Jul 14, 2009 12:42 pm Post subject: |
lexal13 wrote: |
On the naviextras.com forum you can find that Omnia is officially supported device now. If you have any particular problems, you can go directly to them:
https://mappy.naviextras.com/shop/mvnforum/viewthread?thread=1936
