mikeshe Lifetime Member
![](modules/Forums/images/avatars/gallery/1_tomtom_x20.jpg)
dhn Frequent Visitor
Posted: Sun Oct 05, 2008 5:08 pm Post subject: |
My initial thought would be to uninstall Home, log directly into TomTom.com with your account id (email address), dl and reinstall Home. _________________ David |
Posted: Sun Oct 05, 2008 5:10 pm Post subject: |
Delete the TomTom Home application from your PC and try downloading/ installing a new copy from This web page, download using the large green button on the left for the device you have got - Mike |
Posted: Sun Oct 05, 2008 5:50 pm Post subject: |
Thanks lads, done as you said..... still getting errors. |
Darren Frequent Visitor
Posted: Sun Oct 05, 2008 5:52 pm Post subject: |
mikeshe wrote: | Thanks lads, done as you said..... still getting errors. |
What OS are you using on your computer? _________________ Darren Griffin |
Posted: Sun Oct 05, 2008 5:53 pm Post subject: |
Windows XP. |
Posted: Sun Oct 05, 2008 5:57 pm Post subject: |
And did you fully uninstall via Control Panel and then reboot before installing again?
HOME is terribly bug ridden and the cause is almost certainly the application itself not playing nicely on your system. If the above doesn't work then the only thing I can suggest is reverting to an earlier release of HOME until TomTom fix the issue. _________________ Darren Griffin |
Posted: Sun Oct 05, 2008 6:09 pm Post subject: |
Thanks Darren, I did uninstall via the Control Panel but didn't reboot. So I just done it properly but it's still coming up with the error. |
Posted: Sun Oct 05, 2008 6:16 pm Post subject: |
Errors after uninstalling AND reinstalling?
If yes, did you go to the link provided to get the firmware? The compressed file on your computer may be corrupt. _________________ David |
Posted: Sun Oct 05, 2008 6:25 pm Post subject: |
dhn wrote: | Errors after uninstalling AND reinstalling?
If yes, did you go to the link provided to get the firmware? The compressed file on your computer may be corrupt. |
I've tried it from the link which didn't work so I deleted it then I connected the TT and let that dload and install it, still with errors. |
Posted: Sun Oct 05, 2008 6:36 pm Post subject: |
Are you using a wireless router/modem when you download? If so, try a direct connection and see if it helps.
You may also want to try to connect your unit using a different usb port, preferably on the back of your computer. _________________ David |
carl_the_cobbler Frequent Visitor
Posted: Sun Oct 05, 2008 7:17 pm Post subject: |
Hello,
As Darren suggested about installing a previous version.
Someone else has had this problem on another forum and they reinstalled V2.2 and the problem disappeared.
This
Stack and bad allocation sometimes mean memory problems.
This could be an issue if your PC is ageing.
Carl
P.S.Try here for HOME 2.2 if you feel you need it
http://www.oldboy.me.uk/TomTomUpdates/
Last edited by carl_the_cobbler on Sun Oct 05, 2008 7:20 pm; edited 1 time in total |
Posted: Sun Oct 05, 2008 7:20 pm Post subject: |
Well I kept deleting and reinstalling and eventually it works okay now!
Computers? I hate the bloody things!! |
eduo Occasional Visitor
Posted: Sun Oct 12, 2008 7:45 pm Post subject: |
It's a shame this was never solved. TTH has the same issue on my Mac and my TomTom Toyota.
(I know it was solved, I meant no solution was found, it just simply started working). This and a page in italian are the only places I've seen this reported. |
Posted: Sun Oct 12, 2008 11:34 pm Post subject: |
I reckon it is to do with the age of the computer you are running home on, or maybe the type of memory installed, the first question I would ask is the Operating System version then is it from PC World or another similar shop. |
