Pocket GPS World :: View topic - TomTom Home2 problem
whoseline
PostPosted: Sun Sep 21, 2008 4:13 pm    Post subject: TomTom Home2 problem Reply with quote
Anyone experiencing problems of TomTom Home deleting your maps/files on your memory card without your authorisation?
Every time I try to update/connect my TomTom One V1 UK regional to TomTom Home, it brings up random updates I already have but when I access the removable card via my computer, there is nothing in it!
When I right click the card via my computer, there is something on it but I can't see the files. Lucky I had a back-up but it gets annoying everytime I want to update my TT.
There use to be gpsfix updates on TT Home quite often, everytime I connected to TT Home, but now since the new TT Home version came out, I haven't seen any available?
The following is what I am using/running it on:
Windows vista sp1
TT ONE V1 regional
App 7.162
UK & ROI v720.1802
gps v1.21
what is the problem?
PostPosted: Sun Sep 21, 2008 11:50 pm    Post subject: Re: TomTom Home2 problem Reply with quote
Ouch! Nasty!
That's a known problem.... try removing all the corrections (yours and others) using the Go's menus and deleting the Home download cache on the PC. Then try updating again.
A bit tricky to say if it's only happening to you. I've heard of Home doing quite a fw odd things, but nothing this serious before!
PostPosted: Mon Sep 22, 2008 7:55 am    Post subject: Reply with quote
Could be something as simple as a corrupted memory card. You could copy all the files off the card, format it and then copy the files back.
I take it you do have a good backup of the card given all the issues you have had?
whoseline
PostPosted: Mon Sep 22, 2008 2:21 pm    Post subject: Reply with quote
when I downloaded the new TT Home. I connected it to my TT and it deleted my map.
I was annoyed and needed it there and then so I brought the lastest UK map as I didn't have an back-up at the time.
Second time it happened, I had a full back up due to what happened 1st time round.
I re-formatted my card twice now due to TT home mess up my memory card plus I have seen the gpsfix update since using the new TT home.
whoseline
PostPosted: Wed Oct 01, 2008 6:42 pm    Post subject: Re: TomTom Home2 problem Reply with quote
It happened to me again. annoying! How do I do the above?
PostPosted: Thu Oct 02, 2008 12:48 am    Post subject: Reply with quote
Sorry, I got that wrong....
To remove the corrections from the Go, you don't use the menus.
You connect to the PC, shut down "Home" if it insists on starting up, launch Windows Explorer and browse to the "ephem" folder on the Go. Open it up and delete the contents.
To delete the cache on the PC, use Explorer again. go to the place Home stores it's downloads (usually My Documents / TomTom / HOME / Downloads, and delete the contents of the "ephemeris" folder.
PostPosted: Thu Oct 02, 2008 7:36 am    Post subject: Reply with quote
They aren't 'corrections', they're the QuickGPS files?
PostPosted: Thu Oct 02, 2008 12:28 pm    Post subject: Reply with quote
If they are anything like the ones I get (that seem to put me 100yds off-course) then they act like "corrections"!
But yes, you're quite right.... my mind must have still been in MapShare mode! Embarassed
whoseline
PostPosted: Thu Oct 02, 2008 12:30 pm    Post subject: Reply with quote
FYI,
I got a TomTom One V1 regional. And the problem is, I haven't seen/had an GPSquickfix update for ages when using the new TT Home.
PostPosted: Thu Oct 02, 2008 12:33 pm    Post subject: Reply with quote
Consider yourself fortunate then! The offer little to most users and at best would save a few seconds and even then only if it had been some time since you last used the device.
PostPosted: Thu Oct 02, 2008 12:42 pm    Post subject: Reply with quote
I'll tell you the REAL reason why I end up with Quickfix downloads....
When I connect to Home (often just for interest, to see how it's coping!) I usually expect to see 3 possible downloads:
1. the v8 software update - which I don't want yet
2. the GPSQuickFix
3. the Mapshare corrections - which are usually broken/unavailable these days.
So I opt for the QuickFix just to see if Home manages to download ANYTHING! Joker
dhn
PostPosted: Thu Oct 02, 2008 1:07 pm    Post subject: Reply with quote
Andy, is your version of map(s) at the 7 level still within the 1-yr window for getting mapshares?
My 7.10 was beyond 1-yr by a few days so I bit the bullet and dl the N8 firmware in order to be able to buy the v8 map of NA.
Of course, as soon as I did, the mapshare servers went down anyway! Censored
whoseline
PostPosted: Thu Oct 02, 2008 1:10 pm    Post subject: Reply with quote
it does take a little longer to find a gps signal which sort of bugs me.
what is the root of the problem you reckon? This only happened since they brought out a new version of TT Home.
PostPosted: Thu Oct 02, 2008 1:22 pm    Post subject: Reply with quote
Great minds....
I was only thinking the other day that it must be getting close to the limit.
Mine are v715 which I think were released in Feb '08, so I've got a bit of time yet.
I suppose it's too much to ask that Home would tell me when the time does run out? Do you get any indication?
dhn
PostPosted: Thu Oct 02, 2008 1:36 pm    Post subject: Reply with quote
Nope! No indication whatsoever....... if TT can't indicate to the masses that they aren't getting mapshares they are entitled to when the servers are down, it'd be too much to expect them to communicate when a user is NOT entitled to any more mapshares. Mad
22.063 (19 Jun 24)
