Surya Occasional Visitor
Posted: Fri May 28, 2004 11:00 pm Post subject: pinouts for gps to RJ11 plug? |
Anyone know what the normal cable connections are for a gps mouse to a rj11 plug are? |
Pc-Mobile Frequent Visitor
![](http://www.pocketgpsworld.com/blank.gif)
Joined: 26/10/2002 10:38:36 Posts: 789 Location: Hong Kong
Posted: Sat May 29, 2004 3:10 pm Post subject: |
It is not universal !!
Every manufacturer use different pin-outs.
RJ11 is used only because it is cheap and readily available but it is not like a say, 13amp plug that you must put which pin to which.
You are out of luck here unless you find someone who has the same systems as yours and is a competant/knowledgeable DIYer and willing to share the information with you. _________________ Pc-Mobile
http://pc-mobile.net/gps.htm |
Posted: Sat May 29, 2004 3:22 pm Post subject: |
I understood that there was a defacto standard emerging?
If not, do you know what the pinouts used by Tomtom are?
Unfortunately I'm dealing with the input side, not the gps output, otherwise it would only take a moment to work it out.
Surya |
Posted: Sun May 30, 2004 3:43 am Post subject: |
We have no knowledge of it.
So it has to come from "someone who has the same systems as yours and is a competant/knowledgeable DIYer and willing to share the information with you." _________________ Pc-Mobile
Posted: Sun May 30, 2004 8:28 pm Post subject: |
OK, I got my meter out and sorted it myself thanks.
If anyone may be interested the following works for me:-
RJ11 4 wire, numbering from the left looking from the back of the plug with the clip at the top:-
X
1, +V power to GPS
2, RX, data from GPS
3, TX, data to GPS
4, Common ground
X
Surya |
Posted: Mon May 31, 2004 3:25 am Post subject: |
So it is easy!
That's what you should have done in the first place. _________________ Pc-Mobile
Posted: Mon May 31, 2004 10:36 am Post subject: |
I don't believe in re-inventing the wheel! |
AlanS Occasional Visitor
Posted: Sat Sep 04, 2004 2:48 pm Post subject: |
That doesn't seem analogous to re-inventing the wheel, that's far too complex a task.
It seems more like having a marketing envelope in front of you addressed to 'The Occupier' and asking your neighbour what is in his letter because it's too much effort for you to open the envelope.
When the guy can't tell you you then open the envelope yourself. |
mnazar Occasional Visitor
Posted: Thu Dec 09, 2004 4:09 pm Post subject: |
I would like to ask you if you dont mind. Thire ar six pinouts on the GPS reciver You have explained about 4 wires. What about the other tow please and you did not mention about which side should we start counting from clock wise or anti clock wise. Please help I got same saution here.. Please please help.
Thank you
MNazar
Surya wrote: | OK, I got my meter out and sorted it myself thanks.
X
1, +V power to GPS
3, TX, data to GPS
4, Common ground
X
Surya | 8O |
Posted: Fri Dec 10, 2004 5:06 pm Post subject: |
Every make of GPS has different pin-outs.
Surya did not say what his GPS was.
You did not say what your GPS is.
The chance of getting your GPS to work with his pin-outs is really very small.
If I were you, I would consult the GPS manufacturer (may be in the manual) rather than wasting your time. _________________ Pc-Mobile
