Pocket GPS World :: View topic - pio icons not working
pacemaker1000
PostPosted: Thu Sep 25, 2008 10:12 pm    Post subject: pio icons not working Reply with quote
some icons come up as a red square
any ideas?
theripper
PostPosted: Thu Sep 25, 2008 10:22 pm    Post subject: Reply with quote
This is because there is no bmp file with the same name as the poi file
ie
abc.ov2 should have abc.bmp to go with it.
theripper
pacemaker1000
PostPosted: Fri Sep 26, 2008 12:11 pm    Post subject: Reply with quote
thanks
worked for one poi i had installed manually but still have two i downloaded from tomtom that have same name that dont work
PostPosted: Fri Sep 26, 2008 12:24 pm    Post subject: Reply with quote
In which case there is something wrong with the bitmap (.bmp) file for those POIs.
Try re-downloading. Which POIs where they?
pacemaker1000
PostPosted: Fri Sep 26, 2008 11:25 pm    Post subject: Reply with quote
bmp opens ok
pio is 'telephone_exchanges'
maybe someone could try it?
cheers
dhn
PostPosted: Sat Sep 27, 2008 12:46 am    Post subject: Reply with quote
The fact the .bmp opens is not good enough. The size MUST be 22x22 pixels and 24 bit to work.
And have you named the .ov2 and the .bmp EXACTLY the same? Case sensitive and all that.
PostPosted: Sat Sep 27, 2008 9:42 am    Post subject: Reply with quote
pacemaker1000 wrote:
bmp opens ok
cheers
Email them to me and I'll check them. darrenATpocketgpsworld.com
pacemaker1000
PostPosted: Sat Sep 27, 2008 12:57 pm    Post subject: Reply with quote
bmp opens ok
cheers
thanks have sent them
PostPosted: Sat Sep 27, 2008 3:44 pm    Post subject: Reply with quote
And returned. The bitmaps were 14 x 14, I have re-sized them, let me know if that resolves the issue?
pacemaker1000
PostPosted: Sat Sep 27, 2008 8:21 pm    Post subject: Reply with quote
hanvnt had it yet please can you re-send?
why was it on tomtom if it was wrong i wonder?
can you point me in the right direction so i can do it myself next time
cheers great work
PostPosted: Sat Sep 27, 2008 8:26 pm    Post subject: Reply with quote
Can you please clarify where this POI file came from, if it was from BT (as your employer great) if it was from TomTom as one of your earlier posts suggest then I don't think they should be hosting this sort of data - Mike
PostPosted: Sat Sep 27, 2008 8:59 pm    Post subject: Reply with quote
Re-sent but I've now uploaded it and it is also now available here.
PostPosted: Sat Sep 27, 2008 10:12 pm    Post subject: Reply with quote
It has been pointed out quite correctly that the POI set in question is for BT exchanges. I confess I hadn't given any thought to the actual POI as I was concentrating on the bitmap.
As I have said before, such POIs ought not to be offered for public consumption for security reasons. Anyone who has a legitimate reason for needing them should be able to acquire them from their employer. I have now removed the link.
If this POI set was obtained from TomTom then they should be notified that offering such data is dubious at best and possibly criminal.
pacemaker1000
PostPosted: Sat Sep 27, 2008 11:24 pm    Post subject: Reply with quote
thanks for your time Darren, actually managed to resize myself and now works ok
take your point about it not being in the public domain though. funny thing was i actuall failed to find it through the company (although i know its there) and then found it on TomTom Confused
cheers
PostPosted: Sun Sep 28, 2008 12:46 am    Post subject: Reply with quote
Going back to the issue of why TomTom were supplying it with an incorrect bitmap... I'm not at all surprised.
They also hosted several new audio files of a type that would not work on their own units. When I pointed it out to them, all they could suggest was that I gave them a negative star rating!
