pacemaker1000 Regular Visitor
Posted: Thu Sep 25, 2008 10:12 pm Post subject: pio icons not working |
some icons come up as a red square
any ideas? |
theripper Pocket GPS Verifier
![Pocket GPS Verifier Pocket GPS Verifier](modules/Forums/images/ranks/verifier.gif)
![](modules/Forums/images/avatars/gallery/avatar_ani_015.gif)
Joined: Feb 07, 2006 Posts: 581 Location: Medway Towns, Kent
Posted: Thu Sep 25, 2008 10:22 pm Post subject: |
This is because there is no bmp file with the same name as the poi file
ie
abc.ov2 should have abc.bmp to go with it.
theripper |
Posted: Fri Sep 26, 2008 12:11 pm Post subject: |
thanks
worked for one poi i had installed manually but still have two i downloaded from tomtom that have same name that dont work |
Darren Frequent Visitor
![](modules/Forums/images/avatars/gallery/dg-caricature-73x73.png)
Posted: Fri Sep 26, 2008 12:24 pm Post subject: |
In which case there is something wrong with the bitmap (.bmp) file for those POIs.
Try re-downloading. Which POIs where they? _________________ Darren Griffin |
Posted: Fri Sep 26, 2008 11:25 pm Post subject: |
bmp opens ok
pio is 'telephone_exchanges'
maybe someone could try it?
cheers |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Sat Sep 27, 2008 12:46 am Post subject: |
The fact the .bmp opens is not good enough. The size MUST be 22x22 pixels and 24 bit to work.
And have you named the .ov2 and the .bmp EXACTLY the same? Case sensitive and all that. _________________ David |
Posted: Sat Sep 27, 2008 9:42 am Post subject: |
pacemaker1000 wrote: | bmp opens ok
cheers |
Email them to me and I'll check them. darrenATpocketgpsworld.com _________________ Darren Griffin |
Posted: Sat Sep 27, 2008 12:57 pm Post subject: |
Darren wrote: | pacemaker1000 wrote: | bmp opens ok
cheers |
Email them to me and I'll check them. darrenATpocketgpsworld.com |
thanks have sent them |
Posted: Sat Sep 27, 2008 3:44 pm Post subject: |
And returned. The bitmaps were 14 x 14, I have re-sized them, let me know if that resolves the issue? _________________ Darren Griffin |
Posted: Sat Sep 27, 2008 8:21 pm Post subject: |
Darren wrote: | And returned. The bitmaps were 14 x 14, I have re-sized them, let me know if that resolves the issue? |
hanvnt had it yet please can you re-send?
why was it on tomtom if it was wrong i wonder?
can you point me in the right direction so i can do it myself next time
cheers great work |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Sat Sep 27, 2008 8:26 pm Post subject: |
Can you please clarify where this POI file came from, if it was from BT (as your employer great) if it was from TomTom as one of your earlier posts suggest then I don't think they should be hosting this sort of data - Mike |
Posted: Sat Sep 27, 2008 8:59 pm Post subject: |
Re-sent but I've now uploaded it and it is also now available here. _________________ Darren Griffin |
Posted: Sat Sep 27, 2008 10:12 pm Post subject: |
It has been pointed out quite correctly that the POI set in question is for BT exchanges. I confess I hadn't given any thought to the actual POI as I was concentrating on the bitmap.
As I have said before, such POIs ought not to be offered for public consumption for security reasons. Anyone who has a legitimate reason for needing them should be able to acquire them from their employer. I have now removed the link.
If this POI set was obtained from TomTom then they should be notified that offering such data is dubious at best and possibly criminal. _________________ Darren Griffin |
Posted: Sat Sep 27, 2008 11:24 pm Post subject: |
thanks for your time Darren, actually managed to resize myself and now works ok
take your point about it not being in the public domain though. funny thing was i actuall failed to find it through the company (although i know its there) and then found it on TomTom
cheers |
Andy_P Pocket GPS Moderator
Posted: Sun Sep 28, 2008 12:46 am Post subject: |
Going back to the issue of why TomTom were supplying it with an incorrect bitmap... I'm not at all surprised.
They also hosted several new audio files of a type that would not work on their own units. When I pointed it out to them, all they could suggest was that I gave them a negative star rating! |
