Kishore12 Occasional Visitor
Posted: Tue Sep 16, 2008 3:50 pm Post subject: speed cameras not working on navman icn520 |
i am having problems putting speed cameras on my navman icn 520. It is coming up with no storage space on device when i try to load them on the device, i have tried to do it on different memory cards but it still isn't working.
Please help |
Darren Frequent Visitor
Posted: Tue Sep 16, 2008 4:19 pm Post subject: |
Are you able to copy a small test file to the card via a card reader? _________________ Darren Griffin |
TheM Frequent Visitor
Posted: Wed Sep 17, 2008 6:33 am Post subject: |
As far as I remember (and it has been a while) you can't put Custom POIs on memory card -- iCN520 (and really most Navmans with "classic" software) will pick up Custom POI only from internal storage. I think you can find some info on workarounds if you search old posts on this forum. |
Posted: Mon Sep 22, 2008 4:49 pm Post subject: |
Darren wrote: | Are you able to copy a small test file to the card via a card reader? | Hi
yes i am another thing is that i tried to put it on a 512mb aswell but i wouldn't work |
Posted: Mon Sep 22, 2008 5:16 pm Post subject: |
And did you read the post from TheM above? _________________ Darren Griffin |
Gee-Pee Lifetime Member
![](modules/Forums/images/avatars/2753245604985889cd11f6.jpg)
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Mon Sep 22, 2008 6:55 pm Post subject: |
TheM wrote: | As far as I remember (and it has been a while) you can't put Custom POIs on memory card -- iCN520 (and really most Navmans with "classic" software) will pick up Custom POI only from internal storage. I think you can find some info on workarounds if you search old posts on this forum. |
That's right, custom POIs can only be loaded to the device memory, not to a memory card. If you have a copy of the manual the details are on pages 89 onwards. Incidentally, as far as I remember, you can load only a maximum of 25 custom files on the iCN500 series. Have you already got other customs POIs on your device? Have you previously loaded any? If so it is worth while removing those you do not use in order to make room for those you need. _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
Posted: Mon Sep 22, 2008 7:01 pm Post subject: |
Darren wrote: | And did you read the post from TheM above? |
I tried to put the cameras on the original navman memory card and it worked once then never worked again after that |
Posted: Mon Sep 22, 2008 7:05 pm Post subject: |
Kishore12 wrote: | Darren wrote: | And did you read the post from TheM above? |
Are they still there? If so, remove them using My Computer - Mobile device. They could possibly be causing some sort of conflict Have you ever loaded them on the internal memory or is this the first attempt? If you have, be sure to remove them all before uploading the new ones via SmartST. _________________ Gee-Pee
Posted: Mon Sep 22, 2008 10:17 pm Post subject: |
On iCN units Custom POI went into special MyPOI folder. If you were running out of space on internal memory, I think there was an undocumented feature to get around that -- you could put your Custom POI files on the card as long as MyPOI folder was created in the correct place AND ALL Custom POI "ini" files were put on internal memory (even for those installed on the card).
This had no impact on 25 Custom POI type limit -- this was hard coded and there was no way to successfully add more (if you tried you usually got unpredictable results). |
