amier Occasional Visitor
Posted: Sun Sep 21, 2008 9:59 am Post subject: Do I disable the camera alert in TOMTOM? |
hi all
i just signed up and installed the pocketgps camera update on my tomtom go 920 traffic. seems stright forward i,m going out for a drive to test
can someone tell ,e do i need to disable the builtin camera alert in the tomtom or do i leave this alone?
wouldnt this conflict with the pocket gps alerts?
Thanks |
john877 Lifetime Member
Posted: Sun Sep 21, 2008 10:05 am Post subject: |
I believe I just disabled tomtom cameras through the tomtom menu and never had any problems !!
Some people prefer to remove them completely |
Oldboy Pocket GPS Moderator
You can leave them enabled if you want to do a comparison.
It's up to you really, but you can just disable the TT Camera warnings in PLUS Services.
Or you can remove the files altogether.
No.13 on the TT FAQs Page will give you guidance on how to do this. _________________ Richard
Posted: Sun Sep 21, 2008 10:19 am Post subject: |
thanks everyone
they are disabled, i followed the guide and everything seems in order.
are there anychecks i should do before i head out and also are 300 yards too close to be warned. the tomtom ones were usully OK when it comes to the distance. does anyone know what it is in tomtom all i can find is time which says 15 secs?
Thanks |
Posted: Sun Sep 21, 2008 6:02 pm Post subject: |
Most users multiply the mph x 10 (30mphx10 = 300yards). IIRC it equates to about 18 secs.
Mobiles are usually up to double that because of the capture range. It's a case of what you're comfortable with.
I have my Mobile setting at a little less than double, to reduce the false warnings from side roads. _________________ Richard
Andy_P Pocket GPS Moderator
Posted: Sun Sep 21, 2008 11:15 pm Post subject: |
Don't forget you can run DEMO routes to check everything is working OK, you don't have to actually go for a drive.
Just set the camera POIs to show on the map (they won't all show up at low zoom levels, but will show more and more as you zoom in), then go to A-B advance planning (also called A-B Prepare route in later software) and use "point on map" to make a route past a camera or two. Once it has calculated, tap "Details" and go to Show route demo". Set the speed to around 200% and sit back and watch the warnings come up (go no higher than 299% speed or the audible alerts won't sound). |
Posted: Mon Sep 22, 2008 6:59 am Post subject: |
hi all
many thanks for all your help and it works a treat, i think the tomtom version shows you the speed limit. this shows the camera but not the speeed limit is it normal?
shows the cameras from other roads, i was on the a1 and it was showing me a camera from a round about to my left
thanks |
Posted: Mon Sep 22, 2008 8:39 am Post subject: |
I can recommend the spoken warnings which can be found here http://www.pocketgpsworld.com/speed-camera-and-poi-voice-alerts.php they just go in the map folder like the speed cameras
Regarding the warnings received from nearby roads I think you have to tick the box on the Tomtom only warn when on route I believe
Do not forget to make a windows explorer back up before you do anything else as the Tomtom software can be a bit temperamental |
Posted: Mon Sep 22, 2008 1:43 pm Post subject: |
amier wrote: |
i think the tomtom version shows you the speed limit. this shows the camera but not the speeed limit is it normal? |
That depends which version of the database you downloaded...
There are three versions:
1. a single file with all cameras. Quickest and easiest to install, but only tells you there is a camera (or mobile site) ahead, but nothing else.
2. a "consolidated by type" set of about six files. These tell you the camera type but not the speed.
3. the full "speed-zoned" set of files where the cameras are split up into each type and then into every speed. So you end up with about 30 categories. This one obviously takes the longest to set up all the voice warnings etc. but gives you all the information.
It sounds like you may have installed option #2, but you sound like you want to use version #3 instead.
Simply delete the files you've got and start again with the speed-zoned download.
[/quote]shows the cameras from other roads, i was on the a1 and it was showing me a camera from a round about to my left [/quote]
There is an option on the TomTom to ignore cameras that are not on your route, but frankly it doesn't work very well as it seems to include entire motorway junctions in the route even if you are just going straight through. |
Posted: Tue Sep 23, 2008 7:28 am Post subject: |
good morning
many thanks for that, i have downloaded option 3 and set it all up, it was stright forward and didnt take too much time. hopefully that will do the trick.
thanks |
