Pocket GPS World :: View topic - Mio 269 spares.
Mio 269 spares.
Soulman
PostPosted: Thu Sep 18, 2008 5:13 pm    Post subject: Mio 269 spares. Reply with quote
All, does anyone know of / can recommend somewhere to buy Mio 269 spares, specifically I'm looking for the little Black plastic socket at the bottom of the unit where you connect the AC mains / car charger.
Alternatively, are there any other spares / sockets that will fit the Mio 269 and enable me to still use the original AC mains and car charger,
your help and advice would be much appreciated,
Soulman.
rfp2001
PostPosted: Thu Sep 18, 2008 7:11 pm    Post subject: Reply with quote
It is unusual for the charger socket to fall out!!!
At the top of the unit is a small slot beside the SD card slot - carefully put a wide bladed screwdriver into the slot and twist: the case will part with a "crack" and you can check if the socket is sliding around inside! If it is then it can be soldered back on - it is a weak point with these units and it is the solder joints which go "dry" or part from the board.
Post back with what you find!
Soulman
PostPosted: Thu Sep 18, 2008 10:33 pm    Post subject: Reply with quote
I'm not in possesion of the unit, only thinking of buying it if (1) the socket is floating around somewhere inside or (2) I am able to source a new socket, (Hence this post)
I am familiar with how to open up / the insides of the Mio 269 and just need to make sure that if the original socket isnt inside the unit I can get my hands on another,
regards,
Soulman.
rfp2001
PostPosted: Fri Sep 19, 2008 11:48 am    Post subject: Reply with quote
You could try here
http://www.pdahut.com/store/home.php?cat=1618&sort=title&sort_direction=0
I guess spares of that nature are going to be difficult to source since these units are now quite old??
CaptainDrift
PostPosted: Mon Oct 13, 2008 11:38 am    Post subject: Reply with quote
MY local halfords had 1 on sale for £30 this weekend
23.032 (12 Mar 25)
